Tension ball v belt replacement
08.05.2020 21:08 # 1
Turgut58
hello friends.308 my western gasoline car had the sound from the tension ball.
08.05.2020 21:08 # 2
Crayzmetin
When you say plug and play, can you describe it in detail. Are the parts you installed original? Does it sound like the lap of the vehicle's belt. So this sound comes out of the same ratio depending on the rotational turn
08.05.2020 21:08 # 3
GokhaN
Hello. If the voice started to come after the change, it should not come, not normal. Sometimes it can make a sound when they tighten the tensioner too much, but when the belt gets used, some noise is cut but not too much. Have you done something else other than this change?
08.05.2020 21:08 # 4
Turgut58
I couldn't detect that much of it, let me see it tomorrow.
08.05.2020 21:08 # 5
Turgut58
I have not done anything other than this change.
08.05.2020 21:08 # 6
Turgut58
It sounds like it is hitting something when you say plug and play
08.05.2020 21:08 # 7
Frt-Aydin
You go where you get it, I changed the apricot with a hoop again
The voice got louder and he got the master upside down.
you go to a master and check again
