Ten Right Headlight Bulb
08.05.2020 20:56 # 1
peugeot207
lamp faded. Short headlights are not on
How do I send the light bulb?
Where can I find the original lamps?
What are the features of these bulbs?
08.05.2020 20:56 # 2
First of all, welcome to us. Not a special lamp, my teacher shortly passes as h7 type long lengths h1. Choose the type and model year of your vehicle when you enter the relevant link, there is information on how to replace a bulb in the practical information section.
08.05.2020 20:56 # 3
Fredgycon
Greetings,
My first message to the forum :) I hope I can help. Since I just changed my headlights, I think I can convey some useful information.
There are hard plastic covers on the back of the headlight when you open the hood. The large dipped headlights cover. When you pull it off, the cover is already immediately removed. Your dipped headlight is in that compartment. There is a wire holding the headlight to remove the headlight, when you pinch and pull the end of the wire, the wire is already detached and the bulb is wasted. Before pulling out the bulb, you need to disconnect the socket to which the bulb is connected. When you pull out the headlight after disconnecting that socket, it will come out directly. If you apply your new headlight in the opposite way from what you did, you will do the headlight change. Pay attention to the cable, do not break :)
