Temperature problem on the ramp
08.05.2020 19:55 # 1
anil92
Hello friends, I had a little accident and the fan and radiator changed but a new problem appeared. The temperature on the ramp comes to the line above 90, although 100 fans are on. In normal traffic, the fan would open where it used to be, but when it turned off, it turned off at 92 degrees 93 degrees, closing it over 90 degrees before changing it. How can this be a problem because I attribute the ramp event to this.
08.05.2020 19:55 # 2
So these days in my car, yours dropped to 90 degrees last summer. I will control the thermostat and temperature sensor and I will probably change it. I will write the result to you
08.05.2020 19:55 # 3
anil92
I'm waiting for your result
08.05.2020 19:55 # 4
obayazit68
I have the same problem, I am waiting for the result ...
08.05.2020 19:55 # 5
talip206
It may be normal for the weather to show a few degrees too hot at this time. I'm connecting to the weather. Of course, if the air conditioner comes into play, the engine gets tired on the long road and on the slopes. talip206 2016-08-03 22:58:17
