Temperature problem
08.05.2020 16:42 # 1
ufuk..
I have read all the past issues to everyone, but I have not seen the problem of my full life. I have 206 xt vehicles, I think the temperature between 90 and 100 is normal, and I am happy if the help of this problem is helpful.
08.05.2020 16:42 # 2
ibrahim YILDIZAK
90-100 is normal. The reason for the fall also when the air conditioner works is the operation of the fan. Nothing to be afraid of, quite a normal situation.
08.05.2020 16:42 # 3
ufuk..
Thanks a lot, my friend was afraid of seriousness.
08.05.2020 16:42 # 4
ibrahim YILDIZAK
It turns on after 100, when the fan and air conditioner are turned on, it still turns on whether it is 50.
08.05.2020 16:42 # 5
ufuk..
You sprinkled so much water in my saoll
08.05.2020 16:42 # 6
mustafa486
summer is near, after a long break I opened the air conditioner. After driving for about 50 km, there is a sound called `` paaat '' and smoke comes out from under the hood covered with steam. I looked at the radiator exploded. The reason was that the fan did not come on and the pressure of the hot water was due to a hidden heat. Radiator changed with 260 TL cost. Cooling system has a hard time turning on the air conditioner. SEE WHEN YOUR FANS ARE OPENED WITHOUT SUMMER. & Nbsp; & nbsp; I'm Saying Seriously
08.05.2020 16:42 # 7
marmarascorpion
Well, you would have torn it again with the radiator and it would have been worse if you had to burn the cylinder head gasket of the engine, it would cost you a lot, they say there is a good in everything.
08.05.2020 16:42 # 8
cey cey
just like the summer has come, the seasons have become painful, it is imperative to make the entrance of the cars into the summer.
08.05.2020 16:42 # 9
ufuk..
I will put the car into maintenance this week, but I need to find a solid and economical master.
