temperature problem?
08.05.2020 14:03 # 1
beddri
First of all, I would like to thank all the friends who share their comments and information with me.
(206 xt 1.6 16v) No problem in normal driving, but when you wait in a little congested traffic or 2,3 lights to stop and get up, the temperature hand will drop to 100 degrees, then it drops to normal degrees, is this normal? I mean, in my other cars, the heat would have remained stable unless there was a very extra condition.
08.05.2020 14:03 # 2
Darkside
Hello, the temperature does not rise to 100 degrees. If it does, your vehicle will start boiling water as it will already be at boiling point. I think the problem you mentioned is related to the fan not being activated. Since the speed of the vehicle increases while in motion, the water circulation increases in parallel, so your temperature is decreasing.
I would say check your water level, fan and fan sender.
Respects
Darkside 2009-05-18 07:10:57
08.05.2020 14:03 # 3
peugeotefe
The first degree of 90 fans is quite normal, the second degree of the fan is activated when the traffic stops and gets hotter.
08.05.2020 14:03 # 4
hasimayaz
She walks b, raz highs in the pej .. The number is normal. The temperature is at a lower level since it is in the wind coming from outside in the walking vehicle. But if you want peace of mind. You can change your temperature sensor and thermostat. All pug if you ask me. Temperature is very high in.
08.05.2020 14:03 # 5
beddri
I understand, Mr. Bey, your comments are very important for me. Thank you very much to the friends who made other comments.
08.05.2020 14:03 # 6
HakanGokdemir
As a former 206 xt user, I would like to say that the situation is normal, when you say it rises to 100 degrees, does the fan come on?
In my car, it even exceeded 100 degrees when the fan came on.
08.05.2020 14:03 # 7
beddri
Yes, when it reaches 100 degrees, the fan comes into play.
08.05.2020 14:03 # 8
HakanGokdemir
Nothing to worry about, normal heat.
