Temperature problem
08.05.2020 19:30 # 1
dsq14
Hello friends. I examined all the forums, but I couldn't find the solution. I was able to write it here. 2001 model has 306 platinum (sedan). For 2 days, the car turns red on the previous line, that is, 110 115 fans. It doesn't work without relying on red. I looked at the air, there is no air, the thermostat fan puller is new .. it does not mix the water, it is lazy. But it affects psychologically. I just came from service. They tied to the computer, they looked, they did not find any problem. Bidet car is hot and cold, it throws water out when the water is opened. I put red antifreeze 1 week ago. And the stop light did not come on at all. Where is the problem, I would be glad if you help me, regards
08.05.2020 19:30 # 2
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
08.05.2020 19:30 # 3
First of all, welcome. the subject has been moved.
08.05.2020 19:30 # 4
First of all my teacher did not seem to open a fan in your comments. I think I would have you look at the first fan roles and the heat sensor. as a result, the thermostat has just changed. If you have the radiator cleaned, it may be clogged.
08.05.2020 19:30 # 5
Barut
It seemed to me that the first fan did not turn on, you first look at the fan resistance, I guess the fan resistance is faulty.
08.05.2020 19:30 # 6
dsq14
Radiator did not get cleaned. The first level is a little bit of mortal pain, but it is not enough, however, when it comes to the level I call the temperature where the car stops, the 2nd fan pain but scary figures. They almost looked at everything. I couldn't leave because of you
08.05.2020 19:30 # 7
then the temperature sensor should be checked, and whether the thermostat was original or sub-industry was installed.
08.05.2020 19:30 # 8
dsq14
As soon as I bought the car, I called the previous owner and asked him to look in detail tomorrow. There is no pejo service in Bolu. I am also doing duty in the district. If I do 32 km and go, does it cause me to get bored on the way, because when I go on the long road, I think about 85s.
08.05.2020 19:30 # 9
If there is no problem on the long road, there is no problem. either the thermostat opens late, the temperature sensor may be defective or the fan speed is insufficient.
08.05.2020 19:30 # 10
dsq14
Thanks for the information, I will write tomorrow details here
08.05.2020 19:30 # 11
You are welcome, teacher, we are trying to show a way according to what you convey.
08.05.2020 19:30 # 12
talip206
I don't think there is a problem with the circulation. It does not overheat in the city when there is a problem in the circulation. First, check the engine temperature on the computer. Is it compatible with the indicator? If the values coincide, have the fan resistance and the temperature checked by the friend as the friends say.
08.05.2020 19:30 # 13
dsq14
This is the first name tomorrow morning.
08.05.2020 19:30 # 14
dsq14
Friends mrb. Now I got out of the industry, the fan puller sub-industry was originally installed. I used the city 90 to 100 temperature. I traveled between cities and went 35 km and went on the ramp. Then, when the car opens its water cover, it throws water out. Do you think the problem continues, shouldn't it stay in the 90s on the long road?
08.05.2020 19:30 # 15
Sir, if you rush when the engine is hot, of course it will overflow normal ballet. I think the temperature is normal
08.05.2020 19:30 # 16
My 206 are at the same values
08.05.2020 19:30 # 17
dsq14
After the car had cooled down, I added about 1 liter of water. Is this water dropped out when the door is opened? Or is it a little water drop from the exhaust
08.05.2020 19:30 # 18
talip206
Around 90 in the city is normal. The temperature is lower with the increase of air flow due to the speed on the long road. Now it looks normal. Follow the water drop event if there is a leak. But do not open the cover when the engine is hot.
08.05.2020 19:30 # 19
dsq14
Thank you for the information. I always used German .. temperature level would be 90a. On the ramp, in the city and on the long road, maybe it is psychological ..
