Temperature problem
08.05.2020 15:30 # 1
Bykalpsiz46
FRIENDS FIRST HELL ALL I RECEIVE PEUGEOT 306 XR AU SEDAN.
WHEN I RECEIVE, I HAVE NO PROBLEMS, AND NOW THERE IS THE MOVEMENT CEILING AFTER I RIDE THE CAR NOW, YOU HAVE TO KNOW THE WHY.
the albaydemirc 2011-05-30 12:55:54
08.05.2020 15:30 # 2
serkan106XR
circulation pump may be broken.
08.05.2020 15:30 # 3
ugur_clskn
Check the water level. Water may be extracting from a permanent place. When the water is low, the temperature rises. Complete the water and then serve it.
08.05.2020 15:30 # 4
berk2309
I think the thermostat is broken, the problem won't be easy in the circulation :)
08.05.2020 15:30 # 5
Bykalpsiz46
thank you guys tomorrow
08.05.2020 15:30 # 6
Is your vehicle really overheating or are you overheated in the display? I will say that if there is no movement in the coolant, but if the indicator is at the temperature, it is due to musur. Good luck with.
08.05.2020 15:30 # 7
Welcome to Bykalpsiz. We would appreciate if you introduce yourself in detail under the heading "Let's Know Our Members". As for your question; How many kilometers of your vehicle is the fuel, how many degrees do you mean when you say the roof is on, does the car turn on the fan when the car is overheated, did you look at the cooling water (please be careful not to create burns on your body), did it decrease, lubricate or change the color? If you can give detailed information about these, you can get healthier answers. The other kind will not go beyond the guesswork.
08.05.2020 15:30 # 8
metin
the temperature rises immediately and stays around 90. If it neither goes down nor comes out, you have nothing.
08.05.2020 15:30 # 9
ALX
How much does it go up when I say ceiling is doing? Does it come red? No problem if it doesn't turn red. Pejoes also run hot, usually between 95-100C.
08.05.2020 15:30 # 10
Bykalpsiz46
[QUOTE = badires] Welcome to us, bypassed. We would appreciate if you introduce yourself in detail under the heading "Let's Know Our Members". As for your question; How many kilometers of your vehicle is the fuel, how many degrees do you mean when you say the roof is on, does the car turn on the fan when the car is overheated, did you look at the cooling water (please be careful not to create burns on your body), did it decrease, lubricate or change the color? If you can give detailed information about these, you can get healthier answers. The other kind will not go beyond the guesswork. [/ QUOTE]
fuel gasoline
based on red
turning on fan
there is a decrease
There's something like greasiness
08.05.2020 15:30 # 11
http://forum.peugeotturkey.com/forum_posts.asp?tıd=14394&title=byk-yaz-fontlarna-dikkat
