Temperature problem
08.05.2020 21:13 # 1
lilokan
friends, my car is 1.6 petrol. The temperature was constantly rising to 100 and occasionally 110. The excuse changed, the result is the same. The thermostat is pierced, the result is the same. We inserted the thermostat completely. The average does not exceed 95 degrees. But I don't know what happens in hot weather. No problem in fan opening. How do we fix this to 90? My master says the last care radiator will change. Like new in the radiator
08.05.2020 21:13 # 2
Do you have any information about when the vehicle's circulation pump has changed? You also have to check the degree digitally
08.05.2020 21:14 # 3
lilokan
[QUOTE = sonerkyl] Do you know when the circulation pump of the vehicle has changed has the possibility of being from the radiator. You also need to digitally check the degree [/ QUOTE]
The vehicle has been around for 8-9 months. I don't know when the circulation pump changed. The friend I bought the vehicle looked like an irresponsible person :) I think it was looked at digitally. The results are the same. First, I have to change my pop or share my radiator
08.05.2020 21:14 # 4
Karacocuk24
[QUOTE = sonerkyl] Do you know when the circulation pump of the vehicle has changed has the possibility of being from the radiator. I also need to digitally check the degree [/ QUOTE] in my teacher 206, the separation of the fan and separate and heat sensor, that is the only one I see is the water system and the fan system.
08.05.2020 21:14 # 5
lilokan
[QUOTE = Karacocuk24] [QUOTE = sonerkyl] Do you have any information when the car's circulation pump has changed? I also need to digitally check the degree [/ QUOTE] in my teacher 206, the separation of the fan and separate and heat sensor, that is, the only one I see is the water system and the fan system [/ QUOTE]
Hodja, there is only one excuse. Another master says that the radiator has a plugged in entrance. He says there is no problem when plugged into the radio. I didn't understand the logic of this
08.05.2020 21:14 # 6
Karacocuk24
[QUOTE = lilokan] [QUOTE = Karacocuk24] [QUOTE = sonerkyl] Do you know when the circulation pump of the vehicle has changed, it is possible that it is from the radiator. I also need to digitally check the degree [/ QUOTE] in my teacher 206, the separation of the fan and separate and heat sensor, that is, the only one I see is the water system and the fan system [/ QUOTE]
[/ QUOTE] I have this overheating problem, if the vehicle stays stationary for hours, if it stays in the traffic, it turns out to be 90 at night, but when I go on the road, it starts to rise immediately, even if it is a light ramp, it goes up to 105 but I have not heard that my car is moving once again with a high noise fan. Before it changed, it was going towards 120. It was good until then, but I started to get thinner from the war, this summer temperature fan fan roles fan resistance and also the fan brain, finally, let me wear a low temperature thermostat, etc.
08.05.2020 21:14 # 7
lilokan
[QUOTE = Karacocuk24] [QUOTE = lilokan] [QUOTE = Karacocuk24] [QUOTE = sonerkyl] Do you have any information when the circulation pump of the vehicle has changed, it is possible that it is from the radiator. I also need to digitally check the degree [/ QUOTE] in my teacher 206, the separation of the fan and separate and heat sensor, that is, the only one I see is the water system and the fan system [/ QUOTE]
[/ QUOTE] I have this overheating problem, if the vehicle stays stationary for hours, if it stays in the traffic, it turns out to be 90 at night, but when I go on the road, it starts to rise immediately, even if it is a light ramp, it goes up to 105 but I have not heard that my car is moving once again with a high noise fan. Before it changed, it was going towards 120. It was good until then, but I started to get thinner from the war, this summer temperature fan fan roles fan resistance and also the fan brain, finally, let me wear a low-temperature thermostat utility etc. [QUOTE]
Hodja, fan, I have no problem
But as I said, it is rising. If we change the circulation pump together with the radiator, two of them, except for workmanship, are over 500 liras. You need to make a point shot for the right piece. I don't know what to do
08.05.2020 21:14 # 8
AydinBeyol
hi, my temperature was over 100 in my 207 vehicle.
08.05.2020 21:14 # 9
lilokan
[QUOTE = AydinBeyol] hi, my temperature over 207 cars was over 100, I do not understand, I took it to the master I knew from these works, he said that the oil was both bad and blackened, we renewed the oil completely, the problem has been improved.
This has never occurred to me, hodja. It might be true. Thank you so much
08.05.2020 21:14 # 10
Burak3405
https://youtu.be/iEifp508bqw ; There is a sudden rise in temperature, a sudden drop in temperature, but the vehicle does not overheat.
08.05.2020 21:14 # 11
[QUOTE = Burak3405] https://youtu.be/iEifp508bqw ; There is a sudden rise in temperature, a sudden drop in temperature, but the vehicle does not overheat. [/ QUOTE]
there may be air in the system. the thermostat may be faulty. the temperature sensor may be faulty.
08.05.2020 21:14 # 12
lilokan
[QUOTE = sonerkyl] [QUOTE = Burak3405] https://youtu.be/iEifp508bqw ; There is a sudden rise in temperature, a sudden drop in temperature, but the vehicle does not overheat. [/ QUOTE]
My teacher, the hot drink has changed. The thermostat was inserted. There is not even a thermostat in the car. But the problem continues
