Temperature problem
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 18:53 # 1
emresensoy307
friends, my vehicle307 1.4 16 my problem is when my water is in the city, I am normally at medium levels, but when I go out of the city, I cannot raise the car as it rises or rises very little. This is a problem.
08.05.2020 18:53 # 2
emresensoy307
guncel
08.05.2020 18:53 # 3
emresensoy307
friends please help.
08.05.2020 18:53 # 4
emresensoy307
guncel
08.05.2020 18:53 # 5
emresensoy307
Don't you have friends who understand this event ....
08.05.2020 18:53 # 6
hsnsnl
[QUOTE = pug206emre] don't you have friends who understand this event .... [/ QUOTE]
There's a problem with the thermostat, teacher, you gotta show me
08.05.2020 18:53 # 7
emresensoy307
Is it necessary to insert a trigger or something to insert this thermostat and how much does it cost?
08.05.2020 18:53 # 8
popeyes
[QUOTE = pug206emre] friends my car307 1.4 16 my problem is when my water is in the city, it is normally at medium levels, but when i get out of the city, i can not raise the car as it rises or raises very little.
First, your thermostat is not broken because you say it's rising in the city
Assuming the thermostat will stay on all the time, you will heat your vehicle very hard.
Replacing a thermostat is not an easy task, but if you can't get the air in the system, 100 TL will cost you 1000 TL.
you have a heater checked.If your car travels in the 70s on the long road, I think everything between 60 and 70 is normal because the weather is very cold,
thermostat price max. You get antifreeze for 30 tl at 30 tl.
08.05.2020 18:53 # 9
emresensoy307
Yes, there is no problem in the city, but when I go out of the city, I see that the temperature point rises one or two teeth but when I stop in traffic, I think it should not be heated in the city.
08.05.2020 18:53 # 10
popeyes
[QUOTE = pug206emre] yes there is no problem in the city but when I go out of the city, I see that the temperature point increases one or two teeth but I do not have to heat in the city if there is a problem with the heater. [/ QUOTE]
you gave the answer to your own question ClapClapClap
As I said at the time, something like that came to my mind, the thermostat event that the friends said might be true.
if you say why
While you are driving in traffic, it seems normal that the water temperature rises a certain amount and the fan of the vehicle gives hot air because the engine is warming up. but still not a very, very hot heat
On the long road, the temperature of the vehicle does not increase since the cold air always comes to the radiator and the thermostat remains open.
so no hot air comes into your car.
in this case I mean
The thermostat, which cannot be opened on time, causes the engine to overheat, the thermostat, which cannot be closed on time, causes the engine to overheat late and the vehicle heater does not heat well.
that is, your vehicle's thermostat is always open and recirculates constantly.
As I said, changing a thermostat is not a difficult task. You can find videos or topics related to it on the internet. your only problem here will be to learn to breathe the system.
Your 100% thermostat does not close.
popeyes 2014-11-24 17:42:11
08.05.2020 18:53 # 11
fætih
The air of the system is already being taken from the central tap in 206.
08.05.2020 18:53 # 12
emresensoy307
A friend of mine who had worked in the service had been able to change the thermostat together with the timing and got stuck on my head.
08.05.2020 18:53 # 13
popeyes
[QUOTE = pug206emre] A friend who had worked in the service had already changed the thermostat with the timing, it got stuck on my head .... [/ QUOTE]
What you need to change is that the circulation timing belt is there
08.05.2020 18:53 # 14
emresensoy307
Thank you guys, tomorrow, the industry road was open to us
08.05.2020 18:53 # 15
popeyes
[QUOTE = pug206emre] thanks for your friends tomorrow is the way of industry gozuk us [/ QUOTE]
Inform us too, let us know
But before you buy a thermostat, let the master check the old one and try the cold cold.
30 tl thermostat
30 tl 3 lt opet antifreeze
20 TL labor
08.05.2020 18:53 # 16
emresensoy307
okay let's see what our lion would say ...
08.05.2020 18:53 # 17
suppor
The same problem exists in me, the master comes in 90a on the tight trend, or the other times are always at 70
08.05.2020 18:53 # 18
popeyes
[QUOTE = suppor] The same problem is with me, the master comes in 90s on the tight trend, or the other times are always at 70
I think 70 is a normal value
08.05.2020 18:53 # 19
albayman
IN MY OPINION:
If the heating heating is normal in the city, if the temperature indicator sees 90, the heating and indicator are normal. while the pointer in the city is 90
the temperature drops quickly to 70 or below when you are out of town (without speeding your vehicle at 90 and 5th gear).
if the pointer is not in the range of 80-90 on the long road
If the heating heating changes noticeably from warm to warm, the thermostat does not turn off.
the problem is either in the thermostat or in the thermostat client.
08.05.2020 18:53 # 20
emresensoy307
it happens just like you said
Page : / 2
