Temperature problem
08.05.2020 19:09 # 1
alaybey
partner 2007 1.6 HDI car ramp on the ramp is over 90 fan opens in almost 100s ..?
I ask others I have not encountered such a problem, I wonder what is the problem. ??
When the temperature increases, it drops in the traction this happens on steep ramps .. !!
08.05.2020 19:09 # 2
serdaralisan
my friend is swelling when the temperature rises, look at it, as soon as the swollen vehicle stacks, change the fan sender, look at the thermostat, maybe the radiator did air, there are a lot of reasons for this, there is a partner peak, the last ramp I used in the workplace did not draw, the temperature rises as you say, but the fan was still opening, the problem in the turbo's pipe was falling from the drilled traction. It feels like I changed the hose, no problem, no, you can not see this problem without seeing it.
