Temperature problem
08.05.2020 17:33 # 1
canozocak
Hello, I registered new in the forum My name is Can 6 months ago, I bought a partner in 2004 but this is my first peugeot um car interest is too much but there is a situation I could not understand recently, the temperature came to 100 degrees, I waited for the fan to open, the fan opened 90 degrees, I stopped, I opened the hood and looked at the top of the radiator There are water leaks, I changed the radiator on the same day.
But now there is a situation that the hover hand does not fix it, it turns on the fan before it reaches 100 degrees, I can't hold the hand at 90 degrees. while the speed is constant at 90 degrees but I get to 4th gear to get overtaking, I am compressing, some temperature level is 95 97, it does not come to the 100 line but there is a strange rise in this case
08.05.2020 17:33 # 2
hsnsnl
Peugeot is a heat-loving vehicle. It is normal for the indicators to come up to 100 degrees, but it creates problems after that.
08.05.2020 17:33 # 3
elsoberano
the same thing happens in mine, the temperature rises up to 100, especially in congested traffic, and then drops to 90 with the fan turned on again
08.05.2020 17:33 # 4
canozocak
Teacher, french cars are generally warm-hearted, working in this way in renaults.
