Temperature problem |
| 08.05.2020 19:24 | # 1 |
48LZ206 |
| 08.05.2020 19:24 | # 2 |
Efe-Pojo |
radiator may be clogged, thermostat may be faulty.
| 08.05.2020 19:24 | # 3 |
48LZ206 |
Dude Thermostat has changed, but I think the condition of the radiator is blocked. There is no antifreeze, there is no car in the car since May, there is a color like water contamination, but I do not know if it affects it.
| 08.05.2020 19:24 | # 4 |
48LZ206 |
Do not have friends who have more information about this topic?
| 08.05.2020 19:24 | # 5 |
65serdal58 |
I had the same problem. I cleaned the radiator.
| 08.05.2020 19:24 | # 6 |
When the ramp goes up, the vehicle exceeds 90 degrees and reaches 100 or even 100. They say to me that there is no heating in the car. 1.4 x line auto |
| 08.05.2020 19:24 | # 7 |
even if the antifreeze ratio is higher in the vehicle, it will pour the coolant a little and add water and the high probability will be improved.
| 08.05.2020 19:24 | # 8 |
48LZ206 |
So you say that you can drain the water completely, put the water from the top, the bottom of the axle, then clean it and fill it with water and clean it, or is there any other way?
| 08.05.2020 19:24 | # 9 |
In my car, when I enter the city traffic, it happens at 100 degrees, when I go on the fixed road, when I do not enter the stop, it stays at 80. Normal says the masters but I do not understand.
| 08.05.2020 19:24 | # 10 |
48LZ206 |
In my opinion, if you say why the wrong falls on the long road, the cold air flow directly hits the honeycombs, but it is quite normal, but the situation you call it came to me a little differently, my brother is turning on the fan. I think as logic, but I don't know, so look at another master, but not between the neighborhood, go directly to the service.
| 08.05.2020 19:24 | # 11 |
The fan has not exceeded 100 degrees, but the fan is running, but it remains 100 degrees unless I get out of the stand.
| 08.05.2020 19:24 | # 12 |
sonerkyl |
[QUOTE = 06MUNGAN47] It has never exceeded 100 degrees, the fan is running, but as long as I do not get off the stand, it remains 100 degrees. Do not worry, my car does not exceed 90 in 100 vehicles in the city intensive traffic, just like yours.
| 08.05.2020 19:24 | # 13 |
I think there is a heat in the genes of the peutos. I have the same values in my car, seeing 97 98 degrees in the city. At the authorized service, they said that there is no problem. One master said randomly the opponent was defective. We need to get used to high values :) If you solve it, share it with us. |
| 08.05.2020 19:24 | # 14 |
As I said, take a 2.5 liter bottle and take the hose to the coolant tank. Then go out on the road a little bit of water, overheat 90i long road, easy to come.
| 08.05.2020 19:24 | # 15 |
It is not normal for the vehicle not to overheat in the city but to overheat the city. CIRCUIT PERMANENTly, the vehicles that have problems in this way do this in my opinion. Secondly, if the amount of water in the additional water container exceeds its max level, there will be a problem because it cannot make a healthy conversion. But the only reason for the temperature that does not rise in the city but rises outside the city is the inadequate circulation. |
| 08.05.2020 19:24 | # 16 |
In the city mine is around 100 out of town 80 But in the old days, my inner city would not exceed 90 same way they went to the service they said no problem I guess the weather is hot in the past or something that used to seem high now is normal.
| 08.05.2020 19:24 | # 17 |
koray |
friends my vehicle goes zanman 95 but I look at where the vehicle is stopped, mashalah 110, as far as I can tell, I'm not doing it
| 08.05.2020 19:24 | # 18 |
Some masters said he might be from his temper, but there is no clear information yet.
| 08.05.2020 19:24 | # 19 |
If there is a full antifreeze, it will do so. In the summer, make a liter of antifreeze water. Get your air out of it. Filling them all in the middle of the water-filled pot max. nevertheless, the pejo 90 does not remain. Revenue reaches 100 at 100 per cent. in traffic comes to 100 again. I climbed the mountain, the white at the very bottom. My car did not overheat.
