temperature indicator urgent !!
08.05.2020 19:32 # 1
dsq14
Hello friends, I live in Bolu. There is heavy snow oil, I got up in the morning and went to the 35 km town and the temperature indicator was at normal levels. I stopped, I got off, 10 minutes later, I got back to the car, I tried to leave the friend, I tried to go on the road, and he felt like he had gone crazy. I looked right, there was no water boiling. Then we have gas station, I waited there for 1 hour, I went, I contacted the contact, but I did not start the temperature indicator, although the car did not work, it comes out. In the meantime, the speed indicator is also zero, sometimes it works sometimes, sometimes it doesn't work, what do you think is the problem?
08.05.2020 19:32 # 2
get well soon, the first thing that comes to my mind is thermostat fever. 2- I say check the fuses. 3-instrument panel may be faulty. If you want, remove the battery terminal, wait a bit and try it like that. I hope your problem will be resolved as soon as possible.
08.05.2020 19:32 # 3
dsq14
The indicator is red at the end, but if I go 35 km when the engine is cool, it would be a problem.
08.05.2020 19:32 # 4
Teacher, check the pipes with your hand Do you have any excessive hardening or anything. What we should say is a risky job. We are trying to help you according to your explanations. Check the spare water tank cover thoroughly, take water with you whatever happens, go slowly by checking it occasionally, but as there is no water reduction, either the thermostat does not open or the temperature sensor malfunctioned.
08.05.2020 19:32 # 5
dsq14
No water reduction, the pipes are not pressurized, so I will go soft, I took water next to me.
08.05.2020 19:32 # 6
talip206
If the speed dial on the display is also misleading, your battery may be running out. Generally, the battery can give these symptoms that are close to running out. Have it measured while you're gone.
08.05.2020 19:32 # 7
video has been added.
https://youtu.be/m59a-ı4ıdg to
