Temperature Indicator Lights Up at Startup
08.05.2020 15:22 # 1
aclern
friends just turned the key before the car even started, and the fan came on and the temperature indicator turned on. The vehicle had stopped for 5 hours and there is no possibility of overheating. I started the car and the fan stopped and the heat light turned on for 10 minutes and there was no change in the heat light and the fan speed. Sinirli In the morning I had the car washed outside, so I think it might have happened. The reasons I can think of may be a problem with the circulation engine or a problem in the thermostat. It probably sounded like a thermostat shortage. I said to consult with experienced friends. Thanks for your help in advance. aclern 2011-05-01 23:23:57
08.05.2020 15:22 # 2
aclern
I opened the subject to the wrong place. I would be glad if it is included in the Faults and Solutions section. aclern 2011-05-02 00:20:43
08.05.2020 15:22 # 3
metin
If the thermostat stays closed all the time, the temperature will increase but it is interesting to do it at the first start. there may be another problem.
08.05.2020 15:22 # 4
Your vehicle's engine temperature (temperature) sensor may be broken, water may be leaking or the cable may have been displaced.
In this video, just as you said, it starts to give an error as soon as you start the car. The temperature sensor of the vehicle in the video was completely removed and video was taken to see the results Embarrassed
[TUBE] mbnqczlrev A [/ TUBE]
Koliva 2011-05-02 10:06:18
08.05.2020 15:22 # 5
metin
koliva bide is on the abs light on the first start of this vehicle, the battery needs to change the battery on the first start because the abs light is on: D
08.05.2020 15:22 # 6
haruncoskun
movement sensor may be defective
08.05.2020 15:22 # 7
aclern
The same problem in the video is mine. I spoke to the master, and the room said the same thing, I think most likely the water escaped because I had just washed the car. If I drive the vehicle for 10 km in this state, I think it will not be a problem.
08.05.2020 15:22 # 8
[QUOTE = aclern] The same problem with the video is mine. I spoke to the master, and the room said the same thing, I think most likely the water escaped because I had just washed the car. If I drive the vehicle for 10 km in this state, I think it will not be a problem.
I guess I can't guarantee that this question will be "nothing good" Gülme
08.05.2020 15:22 # 9
metin
In fact, nothing happens when the engine is cold, it gets hot until it goes there, but the fan will run constantly, or the vehicle that will try to cool down can disrupt the fan or its brain may go crazy :(
08.05.2020 15:22 # 10
I think the heat sensor
08.05.2020 15:22 # 11
aclern
[QUOTE = ose307] heat in my mind [/ QUOTE]
I think that it will not show any heat even if it is from the heat sensor. Of course, I am not very experienced, but I just think so.
Thank you very much for the help. Alkış
08.05.2020 15:22 # 12
monur
I think the sender will either have a blue or yellow socket if you want to remove it and plug it in. It is likely to have been in contact with the cable.If there is no change, I think the master will be at the head of the vehicle, the distance of 10 km is not a small distance.
