Temperature indicator
08.05.2020 21:08 # 1
Mustafa Aksoy
Hello 207 1.4 2-3 km after I hit the road in my diesel vehicle, the temperature indicator starts to increase. But there is a kalarifer temperature inside the vehicle. I don't know if it's linked to each other. My car is dripping water from the back of the thermostat. Do I need to change my complete thermostat? Despite very little water loss, sometimes the water container is completely empty. Have you ever encountered such a problem?
08.05.2020 21:08 # 2
GokhaN
Hi
I think that you generally need to change the radiator in the container and the hose. Was it new for a long time? If it was new, antifreeze could be caused by changing it
08.05.2020 21:08 # 3
Mustafa Aksoy
It has not been new for 1-2 months. Let's say when winter starts. But there are traces of water dripping on the thermostat, and when I look under the car in the morning, it's wet. I'm suphinged from the thermostat.
08.05.2020 21:08 # 4
Frt-Aydin
[QUOTE = Mustafa Aksoy] Hello 207 1.4 2-3 km after I hit the road in my diesel vehicle, the temperature indicator starts to increase. But there is a kalarifer temperature inside the vehicle. I don't know if it's linked to each other. My car is dripping water from the back of the thermostat. Do I need to change my complete thermostat? Despite very little water loss, sometimes the water container is completely empty. Have you ever encountered such a problem? [/ QUOTE]
It is quite normal that hot air comes into the vehicle.
but you better consult a good master
Did you know if you had put antifreeze or not?
have the thermostat checked
observe for a while
Check out the radiator as our Gökhan friend said
You'd better observe where the petegin is on the driver's side.
In my car, there was a little bit of water loss. I never looked at the honeycomb. Jewelry one day when the driver's head was soaked.
08.05.2020 21:08 # 5
Levent206xt
The man is dripping water from the thermostat, what the radiator is, the liquid that removes the thermostat, will be replaced again with the gasket. If the water drop continues after that, the master looks elsewhere.
08.05.2020 21:08 # 6
Mustafa Aksoy
Thank you for informing you with your comments. I got to the master. He looked roughly because his work was intense. 90% thermostat needs to be changed, he said. After a few days, I will leave it for change. My hand is tired for this kind of work, but I don't want to tamper. Compressed interference between the pieces was difficult to find.
