temperature indicator
08.05.2020 15:02 # 1
arslanbey01
I am a 2006 peugeot 307 1.6 comfor vehicle user. The temperature indicator in my car can reach 70-80 degrees if I stop and get up very often, but when I do not stop, the temperature indicator is slightly above 0 but it stands at almost 0. However, if the stop and go events become more frequent, they rise. It can reach 70-80.If I stop and wait as long as the temperature is high, I do not stop the vehicle, the temperature drops near 0 after a while. If I do not stop and go on the long road, the temperature is close to 0 do you think this is normal or where is the problem. When we stop and get up, Ni moves up. I would appreciate if you answer, thanks.
08.05.2020 15:02 # 2
arslanbey01
By the way, the place where I live can have an effect on night -25 day -10 outside of Erzurum.
08.05.2020 15:02 # 3
As you said 0, I think it starts from 60 or so. I don't think it's a problem in your car, especially in those climatic conditions. Koliva 2011-01-16 17:06:15
08.05.2020 15:02 # 4
erdal
I think there is an abnormality, no matter how cold the weather, the engine will be at a certain temperature .. there may be a problem with the thermostat.
08.05.2020 15:02 # 5
oguzhan29
so it is useful to show you to remove the worm that falls into you, but I guess nothing will happen
08.05.2020 15:02 # 6
Dayyyyy
benedez looks normal. I would say show it anyway.
08.05.2020 15:02 # 7
metin
It doesn't show below 70 anyway. If we look at the weather conditions there, it seems quite normal.
