temperature indicator !!!
08.05.2020 15:23 # 1
werty
friends, the way I do my temperature, no matter how long I do, it looks like the following. but it does not exceed 80 at normal cruise speed. This is normal. I have reads in the forum, such as low temperature, it will burn more than 8.2 liters of fuel in 100 km. If you say there is a saddle problem, I will have to look at the industry tomorrow. 1.6 16v 110hp gasoline.
wertyu 2011-05-06 20:18:10
08.05.2020 15:23 # 2
is the vehicle diesel?
08.05.2020 15:23 # 3
diesel, look at the tank fulll Embarrassed
08.05.2020 15:23 # 4
werty
1.6 gasoline
08.05.2020 15:23 # 5
metin
your thermostat is defective always on, engine does not heat Thumbs Up
edit: Cem, hear my voice (:
08.05.2020 15:23 # 6
werty
friends problem after changing thermostat thermostat reached 90 a pointer. to the attention of malfunctioning friends
08.05.2020 15:23 # 7
cerci07
Thermostats open at 80 in 1.6 diesels cerci07 2011-05-07 14:15:26
08.05.2020 15:23 # 8
onur1980
In fact, it stands at the same level, if there is no traffic, just below 80, if there is a bit of traffic, 80 of them lightly passes to 90, and the fan hurts and falls to 80 again. and the vehicle burns around 270 cents a lpg. The reason could be a thermostat. vehicle 206 xs 1.6 onur1980 2011-05-11 14:35:33
08.05.2020 15:23 # 9
onur1980
The oil indicator on your right stands at the stern. I wonder if it's always 90
