temperature indicator
08.05.2020 17:03 # 1
kemaldeveci
206 sedan 2010 model even when the engine is cold, the temperature gauge is running after starting the car fan is constantly working. What is the problem?
08.05.2020 17:03 # 2
berk2309
either the temperature sensor is defective or the thermostat
08.05.2020 17:03 # 3
muro_60
the temperature sensor is intense.
08.05.2020 17:03 # 4
bjkamil
yes, the temperature sensor is defective. it happened to me too. the piece is breaking down quickly.
08.05.2020 17:03 # 5
OsmaN06
If the fan turns on, there is no problem with the thermostat, most likely the temperature sensor.
08.05.2020 17:03 # 6
sevkituruc
slm ... & nbsp; rolland garros 2002 & nbsp; i had the same problem i was looked at service and private service .. all overhearted and so on changed everything including cables .. & nbsp; but the problem is not solved. & nbsp; I sent mail to france .. answer & nbsp;
was very funny .. and it was true ... I have been using it for 1 year without any problems ..
< / div>
replace the battery. message came .. I changed the battery ... everything is back to normal. & nbsp; if there was a tube, especially the amp must be high .. I hope I helped .. good day ...
