Temperature From Driver Part
08.05.2020 19:57 # 1
samet206
The place where I added the picture of Sa friends is the side of the gas pedal under the console. The place where the radiators are located. This region is too hot. I was never stuck. Could it be a problem or should I meet normal due to the air temperatures?
samet206 2016-09-01 01:41:56
08.05.2020 19:57 # 2
Daimon
The same thing happened to me, I called the master, he said there is no problem, he gives warmth from time to time, your right foot is a little burned, is it constantly or occasionally?
08.05.2020 19:57 # 3
Occasionally it happens in me, teacher, I think the temperature is not a problem
08.05.2020 19:57 # 4
KILIC
In my 307 it was that way, I removed the cover, I placed white foam between the heater core and the cover, it was cut off.
08.05.2020 19:57 # 5
GokhaN
If it does the same problem without directing it to the foot, there may be a problem in the feet that direct the ventilation.
08.05.2020 19:57 # 6
samet206
[QUOTE = Daimon] The same thing happened to me, I called the master, he said no problem, he gives warmth from time to time, your right foot is burning a little, is it continuous or occasionally [/ QUOTE]
First of all, thanks for the answer. I have not been disturbed by such a thing before in 2010. This made me think that I have a problem directly.
08.05.2020 19:57 # 7
samet206
[QUOTE = sonerkyl] is occasionally in my teacher, I think the temperature is not a problem [/ QUOTE]
Thanks for the answer, I couldn't see a problem right now, but I am observing the situation.
08.05.2020 19:57 # 8
samet206
[QUOTE = KILIÇ] It was like that in my 307. I had removed that cover.
Thanks for the answer. If I am not mistaken, the 307 does not look that way either side, so there is another cover left in my mind that it is not open like that.
08.05.2020 19:57 # 9
samet206
If [QUOTE = GökhaN] does the same problem without directing it to the foot, there may be a problem in the feet directing the ventilation. [/ QUOTE]
Thanks for the answer. This was the first thing that came to my mind. Then I said what could not be used during the summer, but I am not sure.
08.05.2020 19:57 # 10
GokhaN
I used 206, but I did not have such a thing, it doesn't matter the model year.
08.05.2020 19:57 # 11
madblueblacksea
I think you should have black foam covering the honeycomb. The temperature of that area is normal and the heater does not cut hot water even if it is off. If you say it is blowing hot, I think there might be a problem with the steering. Give the control to the glass and observe the bidet
08.05.2020 19:57 # 12
samet206
Thank you, teacher, in all the 206's that I got there, this region is not an extra part of the rate, I don't know if there is something different.
08.05.2020 19:57 # 13
madblueblacksea
[QUOTE = samet206] Thank you, teacher, in all the 206's that I got there, this region is not an extra part of the rate, I do not know if there is something different.
You did not get on my 206 :) There was a slight dripping at the entrance of the honeycomb. I will upload the picture of the piece when available tomorrow
08.05.2020 19:57 # 14
KILIC
[QUOTE = samet206] [QUOTE = SWORD] was like that in my 307, I removed that cap I placed white foam between the heater core and the cap was cut off temperature [/ QUOTE]
Exactly there is a cover in the 307s. Even though there was a lid, the temperature was felt seriously. Of course gaziantep was ruining the heat in a hot one. I removed the cover, put black foam between the cover and the honeycomb, I closed it, it was cut hot. Actually, you can adjust it from those black foams accordingly.
