Temperature at -10 degrees
08.05.2020 21:27 # 1
Ve da
Hello friends. My car is a peugeot 307 2004 model diesel. There was no antifreeze in my vehicle, but water decreased, I always added an 0.75 liter antifreeze at -30 degrees. This morning, I went to the full cold at -10 degrees cold. The car warned that the water was running low. I got off and looked, the water in the radiator is boiling. After waiting for the boiling to stop, I put antifreeze-water mixture on the discharged radiator. But I'm afraid to run tomorrow. I do not know what is the adequacy of my antifreeze, but I could not. What would you like me not to do? Also, do you think there is something wrong with what I live today? Thank you from now
08.05.2020 21:27 # 2
talip206
Did he give the warning because the water was missing, or did he give the temperature? There is nothing to be afraid of if he has given water loss. There is a leak at most.
But if he warned of heat, the gasket can go up to burning. It should not be overheated easily in this weather. The thermostat may not have opened, may not have been recirculated because the water is frozen, or worse, it may have dismantled the circulation. It is useful to take it to the master as soon as possible.
08.05.2020 21:27 # 3
[QUOTE = talip206] Did he give the warning because of lack of water or did he give the temperature? There is nothing to be afraid of if he has given water loss. There is a leak at most.
+1 Clap Just as our friend said, I think my teacher go directly and have it checked.
08.05.2020 21:27 # 4
Ve da
When I took the heat that day, I looked at the temperature around 100. I did not get out the car the next day when the weather was very cold. Water warning on the screen warning: I have translated "top up engine coolant level" and it says "Fill the engine coolant level". After a few days, when the air turned to noral, I took the car out. I did a 15 km long road and I did not decrease 30 km of water in total. One eye was in the temperature indicator. Up to 80-90 he did not go beyond. Then when I got home, I looked at the water, but there was no shortage. How can I be sure if something has happened on the top or not? I have not been able to get to Heta yet. If there was a leg, the water would not decrease, friends in the next uses.
08.05.2020 21:27 # 5
Ve da
Sorry, I wrote the answer a little late at night. Tesekkur Tesekk for your interest
