Temperature and Water Indicator problem EMERGENCY
08.05.2020 20:29 # 1
kaancevik06
Friends 2004, 1.4 Hdı, my car lights up the water lamp and goes back when I put half a glass of water. The overheat indicator is also around 80 at idle, showing 80-90 when the vehicle is walking. What is the problem in your opinion?
Is this a crack in the water tank? Or is it from the gasket? kaancevik06 2017-07-28 18:40:30
08.05.2020 20:29 # 2
Selox
The heat of your vehicle will be between 80-90. It gets between 90-100 in hot weather. There is a maximum of 110 on the slope, up to 110 is normal. But I can't say anything to the light burning thing. You have to looked at.
08.05.2020 20:29 # 3
no problem, temperature is normal. water level switch may be faulty or the replacement water tank cap is defective.
