Temperature 70 degrees ...
08.05.2020 21:13 # 1
Falderal06
Greetings ... I have a 2004 model partner 2.0 hdi vehicle, the temperature gauge always keeps slightly below 70 degrees while driving, it is only around 85 degrees in congested traffic and idling. Is this normal or is it a messenger of a problem?
Note: Timing set and naturally changed thermostat ...
08.05.2020 21:13 # 2
talip206
With the timing, the circulation varies, not the thermostat. The problem you mentioned seems to be a thermostat problem. Your thermostat may be constantly open.
08.05.2020 21:13 # 3
iso0625
Yes, the circulation varies with the timing. Father Mercrdes had been the same, the temperature could not reach 85 degrees. Thermostat changed and improved.
08.05.2020 21:13 # 4
Falderal06
[QUOTE = talip206] With the timing, the circulation varies, not the thermostat. The problem you mentioned seems to be a thermostat problem. Your thermostat may be on all the time. [/ QUOTE]
The right circulation has changed ... Let me go to a service so thank you ...
08.05.2020 21:13 # 5
Falderal06
[QUOTE = iso0625] Yes, the circulation varies with the timing. Father Mercrdes had been the same, the temperature could not reach 85 degrees. Thermostat changed, improved. [/ QUOTE]
Thank you so much...
08.05.2020 21:13 # 6
kaan206
I do not think it will be from the thermostat bn thermostat and I changed all the consumers the same problem continues
08.05.2020 21:13 # 7
Falderal06
[QUOTE = kaan206] I don't think it will be from thermostat bn I changed the thermostat and all the customers and the same problem continues [/ QUOTE]
The morning changed from the thermos, but it got better, but this time when the 85 degree was over, the fan started to open ... I do not understand the temperature does not rise to 90 degrees ...
08.05.2020 21:13 # 8
talip206
The indicator may be showing a little low. Normally the first stage fan (slow stage) turns on at 95 degrees and the second stage fan (speed fan) turns on at 105 degrees. Connect it to the computer and check if the display and actual temperature are the same.
It probably looks a little low.
08.05.2020 21:13 # 9
Falderal06
[QUOTE = talip206] The indicator may be showing slightly low. Normally the first stage fan (slow stage) turns on at 95 degrees and the second stage fan (speed fan) turns on at 105 degrees. Connect it to the computer and check if the display and actual temperature are the same.
I went to the master again, because Mersin is a hot country, he wore a thermostat that opened at 83 degrees, the temperature does not see 90 degrees, so when he came to the fan, he did something to the computer and opened it after 90, said first level ... Thanks for your help ...
