Temperature
08.05.2020 20:33 # 1
307XS307
Hello friends. I had to go to ATM around 11-12 tonight tonight. I started the car, but I put the fan in the heat to get the vapor out of the window before it even warms up, and finally I saw the temperature rising after 5-10 kilometers. I came to nyse atm, took care of my job, I ran it again, the temperature bar suddenly came to the end without going 3 kilometers, and the trip computer gave a warning and also the stop letter was flashing under the temperature bar. I went down and looked at the water. After 10 minutes, I started it again after 1 kilometer, the heat bar came to the end again, the stop and the same warning came on again, but since it was closed at that time of the night, I brought the car to the house like that. the car had never been overheated.
Note: I think this is the case because I was stupid when I started the car and turned on the fan. Do you have a solution, what should I do?
Vehicle: 2004 model 307 xs 1.6 automatic
08.05.2020 20:33 # 2
Orcun.Dmr
There may be a problem with overheating or socket plugging into customer . At some point, it was the same way you said in my car. I went down and looked without panic. One of the cable that came to the socket of the client was broken, fixed it with my hand and came home until it soldered at home. I hope it's like mine in your problem. orçun.dm is 2017-09-14 02:35:03
08.05.2020 20:33 # 3
whisky
Temperature sensor failure, circulation pump failure, vehicle gasket burning, thermostat failure, general causes that may cause heat. When the thermostat fails, the temperature is always low, but I said I should write it anyway.
08.05.2020 20:33 # 4
talip206
Do not be afraid if there is water in the car. But do not be afraid if the water is over and the heat lights are on. There is probably a malfunction.
08.05.2020 20:33 # 5
aykutbayram1996
It can be electrical to make a ceiling at a time of normal flow.
08.05.2020 20:33 # 6
ggitaristt
In every malfunction related to the cooling system of the 307s, it gives warning by ending the temperature bar. I have never seen 100 degrees in the temperature indicator.
So the car is not overheating, it shows a malfunction ..
08.05.2020 20:33 # 7
307XS307
but when friends stop and get off the car, there is a smell of heat from the front
08.05.2020 20:33 # 8
aykutbayram1996
If you consult a service, even if you look at the master cooling system, pipes may be clogged, the circulation thermostat will see all of them, and you may have eaten the upper close gasket.
08.05.2020 20:33 # 9
ggitaristt
[QUOTE = 307XS307] but when friends stop and get off the car, there is a smell of heat from the front [/ QUOTE]
Does your fan turn on when the temperature rises? The resistance may be broken. Look at the temperature sensor. Check the thermostat while it is done.
08.05.2020 20:33 # 10
307XS307
I will write here as a result of my friends who will take you to the industry tomorrow. here the car is not working in the first start, sometimes in the 2nd start, due to a problem caused by the lpg. In this lpg problem, use the vehicle for 600 km on the long road in gasoline.
08.05.2020 20:33 # 11
Nihat ozel
I use 206 xdesing 1.4 gasoline. The water in the reservoir where I put water is rising may cause friends.
08.05.2020 20:33 # 12
boruc
[QUOTE = Nihat ozel] I am using 206 xdesing 1.4 gasoline. The water in the reservoir where I put water can be rising.
It is normal for the water level to rise when it is hot. Because the water is expanding.
But I know that the water squirt will be from the gasket if there is a bubble or something
08.05.2020 20:33 # 13
ggitaristt
If air remains, water rises in the circulatory system .. check this first .. otherwise ..
There is a possibility that the gasket is burnt.
