Temperature
08.05.2020 21:24 # 1
S4207tr
Greetings 2003 partner 1.9 ac model car's temperature indicator on the instrument panel until the level of danger rises, also when the engine fan is running when the vehicle is stopped, that is, the fan shuts down when the ignition is switched off .... thank you ...
08.05.2020 21:24 # 2
GokhaN
Greetings normal, these air fans do not need much, while cooling is around 100-110 borders, there is something problematic.
09.08.2020 20:02 # 3
S4207tr
Thank you so much...
10.08.2020 00:32 # 4
aegeanxtr
I use 307, when it approaches the second line after 90, the fan turns on, in the user manual, it is shown as the normal operating temperature after 70 and up to the second line after 90. When it stops, it is normal for the fan to stop because the fan does not work because the water circulation also stops.
10.08.2020 07:23 # 5
S4207tr
I'm not saying for a partner, some vehicles work even if you turn off the ignition, the radiator cooling fan works until the radiator gets colder so I asked ... tshk ...
