Temperature
08.05.2020 21:28 # 1
Pegoutmete
Hello friends, we are together with a new subject, the vehicle does not mars when the temperature reaches 100. The vehicle takes self-security, probably because it starts 90 gold, but the problem is that the vehicle temperature normally does not increase to 90, but when it stops, I find 100. So, I cannot stop in the city. If you have a low temperature, if you take a low temperature fever, if you open it early, the problem will be solved. Pegoutmet to 2020-02-18 20:51:39
08.05.2020 21:28 # 2
talip206
What exactly do you mean when you say that starter doesn't start? Does the starter say click or not, or the starter is running, but the car does not work.
If it clicks and does not work, the starter motor has run out of coal. Starter does not start because it sticks when it gets hot.
Otherwise, there is no feature whether or not to protect it when it passes to a certain degree.
08.05.2020 21:28 # 3
Pegoutmete
Mars is teak, but the engine of the mars engine has been maintained for 1 month.
08.05.2020 21:28 # 4
ismailkaya
You get the electrician to take care of the starter of the starter.
08.05.2020 21:28 # 5
Pegoutmete
When the mars tooth is broken, it sits in its place when it is cold but it does not sit when it is hot
08.05.2020 21:28 # 6
Pegoutmete
friends, now i met with pegout authorized service said that the vehicle is not getting bought after overheating 100 because it is safe
08.05.2020 21:28 # 7
EmSul
Is the vehicle diesel
08.05.2020 21:28 # 8
ismailkaya
The starter gear coincides with the flywheel gear. When the teeth do not sit together, you hear the sound that you click on the marsa. The teeth do not sit, then the starter does not start.
08.05.2020 21:28 # 9
EmSul
If it is diesel, I do not know the diesel, but if it is gasoline, it is not possible to protect the helix around 100 degrees. Normally, it will see 110 degrees.
08.05.2020 21:28 # 10
Pegoutmete
[QUOTE = EmSul] Is the car diesel [/ QUOTE]
No
08.05.2020 21:28 # 11
Pegoutmete
[QUOTE = ismailkaya] The starter gear coincides with the flywheel gears. [/ QUOTE]
Aga, I say something, why is the temperature when it is 90 degrees, it doesn't sit when it is 100 degrees?
08.05.2020 21:28 # 12
Pegoutmete
[QUOTE = EmSul] If diesel is not possible, I do not know the diesel, but if it is gasoline, it is not possible to protect the helix around 100 degrees, normally it is 110 degrees.
President, your car gasoline is in high temperature, I usually have 89 thermos in your thermostat.
08.05.2020 21:28 # 13
talip206
[QUOTE = Pegoutmete] friends now I met with pegout authorized service because the vehicle is not getting started after overheating 100% because it is self-confident [/ QUOTE]
Until now, I started the fever at 110 and worked when it was higher. It would be absurd to have such a feature because the temperature is over 100 when the temperature stops at 90 and the ignition is turned on after 5 minutes. Then he should never start.
You have the starter motor checked.
08.05.2020 21:28 # 14
EmSul
This is my 3rd gasoline peugeot, and the temperature of 90-100 plays continuously. It comes out at 110a and it is very normal. The system of the vehicle would be like this, even if I had 206 gti, I would last for 5 hours, I would stop and fill the water in 30 minutes. water was flowing and was discharging because it was broken, smoke was coming out from the water tank :)
08.05.2020 21:28 # 15
Ali
It seemed strange that the temperature increased after stopping. Are there any water leaks?
08.05.2020 21:28 # 16
ctuncel90
Hello, I just joined you.2005 gasoline 206 I bought last week, while on the way, the temperature of the ceiling has lasted until the end. the stop lamp has started flashing. 5- 10 km I went, I parked the car. When I got on again after 1-2 hours, the temperature indicator had fallen to the bottom. The temperature was coming and falling in traffic until 90, and the day came to 90, the fan turned on slowly as it fell to the bottom of the red line. I think it was a chronic desire but nobody shared its solution. If the temperature has changed, the manager continues to do the same. If someone fixes the problem before, can he offer me a master or a solution?
08.05.2020 21:28 # 17
talip206
[QUOTE = Ali] It seemed strange that the temperature rise after stopping. Are there any water leaks? [/ QUOTE]
No, even if there is no malfunction. As the engine stops, there is no circulation. Thus, the temperature of the engine heats the water a little more and the reader reads the temperature too much. When it starts, the circulation starts and the water temperature drops.
08.05.2020 21:28 # 18
talip206
[QUOTE = ctuncel90] hello I just joined you.2005 gasoline 206 bought last week when I was on the road, the temperature of the ceiling suddenly lasted until the end. the stop lamp has started flashing. 5- 10 km I went, I parked the car. When I got on again after 1-2 hours, the temperature indicator had fallen to the bottom. The temperature was coming and falling in traffic until 90, and the day came to 90, the fan turned on slowly as it fell to the bottom of the red line. I think it was a chronic desire but nobody shared its solution. If the temperature has changed, it will continue to do the same. If anyone fixes the problem before, can you offer me a master or a solution? [/ QUOTE]
Classic fan role malfunction. Remove the place where the Peugeot coat of arms is located. There is something like a closed box when you open it, there are two green fan roles. They made oxide or the thick cable was broken due to oxide.
In addition, there is a fan resistance close to the same area. It is useful to change it when it is opened. It is not very expensive parts.
08.05.2020 21:28 # 19
ctuncel90
thank you so much....
