Temperature
08.05.2020 21:00 # 1
adnankaraevli
SELAMLAR PAGE Yeniyim PEJO 206 YES 1.6 GASOLINE * LPG standing HEAT 120 YE BASED in LIGHT AND 120 DE FAN OPEN CAR Motion for ON think back down to DECREASE the HEAT Musuri AND THERMOSTAT CHANGED IS STILL THE SAME TEMPERATURE PERMANENT END DAYIYO SEAL BURNS SAYS I LOOK We suspect BURN NOT CAUSE In SEALS WHAT PLEASE COULD YOU HELP
08.05.2020 21:00 # 2
eran
the cooling elements need to be checked by a good master
08.05.2020 21:00 # 3
talip206
[QUOTE = adnankaraevli] SELAMLAR ON THE PAGE I am new PEJO 206 YES 1.6 GASOLINE * LPG turns on when the light stops, 120 turns on and the fan turns on, the movement moves again, the line is moving, the line is moving and the line is moving. WHAT IS THE REASON NOT BURNED, PLEASE HELP [/ QUOTE]
The fan relay is faulty. When the role is not activated, the fan turns itself on automatically.
Remove the location where the peugeot ambulance is on the front of the role. There is something like a box next to the radiator. There are two green roles in it. Check them out. It is probably oxidized. Or the cable is damaged.
08.05.2020 21:00 # 4
adnankaraevli
There are 3 cables on the fan sender. 2 cables are cut white. 2 cables are connected. the adnankaraevl 2018-08-30 12:15:39
08.05.2020 21:00 # 5
talip206
[QUOTE = adnankaraevli] There are 3 wires on the fan sender, the white cable is cut, 2 wires are connected so can it open late? [/ QUOTE]
I remember the two wires. Have you checked the roles?
08.05.2020 21:00 # 6
adnankaraevli
I am at work, I hope I will go in the evening and check it
08.05.2020 21:00 # 7
adnankaraevli
The roles have been checked.
