Temperature
08.05.2020 19:46 # 1
Mehmetayas
My car peugeot 206 overheat always stops at 90 and turns off at 90, do you think this is a problem or does my original look like that?
08.05.2020 19:46 # 2
ssakyel
When I said that it hurts at 90 and turns off at 90, when I first started the engine, I didn't understand if it worked with 90 degrees and always stayed there.
08.05.2020 19:46 # 3
Mehmetayas
Ewt is exactly the same thing it does, it didn't work like that
08.05.2020 19:46 # 4
ssakyel
It is not normal to arrive at 90 in the first run. There may be a problem in the display or temperature sensor. If the vehicle overheats in the future, you may not see this, which may lead to greater troubles. I recommend you to have it checked when you are available.
