Temperature
08.05.2020 17:28 # 1
maestro
Hello friends, the weather around 15-20 degrees is around 90 in normal conditions. When I stopped the car and started it for a short time, the temperature was around the line after 90. In a short time again, it goes down to 90 again. or are these levels normal? thanks. (by the way, after the 90's, the fan turns on)
08.05.2020 17:28 # 2
I don't know much, but it doesn't feel like normal to me.
08.05.2020 17:28 # 3
It is perfectly normal, even this is what it should be.
As you know, the water circulation pump, which provides the water circulation in our vehicles, gets its power from the engine. When the temperature is 90 degrees, when you stop your vehicle, the water circulation stops, so the current temperature in the engine passes to the coolant. This can be 5 degrees or 10 degrees and 15 degrees. In other words, it is normal to see the temperature at 100 degrees when you turn the contact again after 10 minutes. It is the unusual temperature that does not drop to 90 again. Dropping from 90 is also abnormal.
08.05.2020 17:28 # 4
cocomo
What is the temperature that should be max temperature at 40 degrees in summer friends? I ask as a general question.
How many degrees should we scratch?
08.05.2020 17:28 # 5
samet206
If it continues to increase after 95, I know that it will increase from normal to 90.If the fan is going to turn 90a, I usually pass 90 on slopes, I do not think that there is something to be afraid in my car.
08.05.2020 17:28 # 6
[QUOTE = cocomo] In summer, what is the temperature that should be max temperature at 40 degrees friends? I ask as a general question.
If the 2nd stage fan still rises after turning on, there is a problem. This point changes according to the vehicle-engine.
08.05.2020 17:28 # 7
Rebel35
yesterday it was exactly as you said yesterday, at 25 degrees air temperature, it went between 90 degrees above the 90 degree line in traffic, if it was a little higher, I would keep the way of the service.
08.05.2020 17:28 # 8
Aziz
Pejos are hotter than other vehicles, working over 90 summers. falls on the long road, runs on a short distance :)
The only thing to fear is whether the fan or fans are approaching 90 when they are running :) If it does not approach you, get closer to the motor, remove the thermostat, drain the water as much as it is empty, turn it off and add water, you will both check and add water :)
08.05.2020 17:28 # 9
qqyyxx
The vehicles usually work at 90, this is the ideal temperature, but in fact, my Opel Corsa came out as much as 110 and it was said that it would not be a problem by the service. but after 90 I always have an uneasiness.
08.05.2020 17:28 # 10
MagicPerformance
This is quite normal Pug group works hot compared to other brands.
08.05.2020 17:28 # 11
elsoberano
let's say that the lion loves heat.
