tarnish rearview mirror
08.05.2020 19:58 # 1
ulas28
Hi friends,
I own 2005 model 307 1.6 xt petrol automatic. My problem is this: The darkening rearview mirror in the car does not light up when I press the button, but it does not darken even though the light is on, I would be glad if anyone knows the reason or can help
08.05.2020 19:58 # 2
akisioglu
The light sensor located in the bottom center of the mirror may be contaminated.
While squeezing and then cleaning another place with the same cloth
The diaper touches the sensor in the middle of the mirror.
Clean inside will be improved.
08.05.2020 19:58 # 3
ulas28
Thanks tomorrow I will report the result I will try the first job
08.05.2020 19:58 # 4
ulas28
Unfortunately, there was no improvement. The place mentioned was clean, but I still cleaned it a bit, but the result is the same. The light is on but there is no decision. I hope there is another solution.
08.05.2020 19:58 # 5
Secks
Is there a film on the back window?
08.05.2020 19:58 # 6
ulas28
Yes there is
08.05.2020 19:58 # 7
Secks
I have it in my vehicle, as you said, it doesn't have much effect. I was tired of being a movie, and I wasn't tampered with. Even if they burn longer than the back, it can be understood as if they are not working because the light is not intense.
08.05.2020 19:58 # 8
ulas28
Tomorrow I will hold a flashlight and try
08.05.2020 19:58 # 9
Secks
Flashlight may not work if the focus is not adjusted :)
08.05.2020 19:58 # 10
ggitaristt
I tried holding the flash of the phone while the green light was on and it got dark after 15 seconds.
08.05.2020 19:58 # 11
conywolker
There is a film on my rear window, but there is no problem with darkening. It lasts for 10 seconds at most.
08.05.2020 19:58 # 12
fætih
as if it doesn't darken mine. lights up but I don't feel it gets too dark. There is a film on the rear window, but it is too dark.
There is a movie in the focustata, it goes dark. I think it's the sensor problem.
08.05.2020 19:58 # 13
Dralp
Thank goodness I have it in my car, when I press the button alone, which button did you say, it has a nail on the back in the middle of me, it takes the form of darkening it.
08.05.2020 19:58 # 14
ulas28
There is a button under the mirror, the light is on when you press it
