tapping
08.05.2020 15:36 # 1
goktug
friends today we run a friend's car by pushing and hitting it 4-5 meters. vehicle 206 x design. what harm does this cause?
08.05.2020 15:36 # 2
It is not beneficial to start the vehicle by shooting. If you don't do it again, you won't have any problems in the future
respects
08.05.2020 15:36 # 3
goktug
I know that. what is the problem we will face?
08.05.2020 15:36 # 4
oguzhan29
Keep the subject up to date, knowledgeable friends will help you
08.05.2020 15:36 # 5
Kemanyak
Man normally does not cause any trouble but sometimes the vehicles may not work because the timing is broken. When you hit it, the vehicle valves will bend and suffer more damage than usual. If the curvature of the valves increases, it will have consequences until block breaking and the engine becomes MORT!
08.05.2020 15:36 # 6
tugrahan
I know if he can survive the sentence
that is, if the trigel belt skips 1 tooth, the valve opening and closing settings are broken
this causes great damage to the engine
08.05.2020 15:36 # 7
It is not a problem that can be encountered in big vehicles such as jump-on-bus, etc.
08.05.2020 15:36 # 8
the masters I know always say ... it will damage the crankshaft and say don't hit it ... ..
08.05.2020 15:36 # 9
sercinho
If there is nothing right now, it will be useful not to do any more in the future.
08.05.2020 15:36 # 10
ali oncu
the same situation happened to a friend who has a diesel vehicle, I think the sibop bent bent the vehicle and charged a lot of expenses I think is a method that should not be used much.
08.05.2020 15:36 # 11
se®k@n
There is always a chance to jump to you ..
08.05.2020 15:36 # 12
As far as I know, pushing has no harm in manual gears. It is not done in automatic vistes. It is already written how to make many cars in the user manual. However, sudden clutch lifts in push-up operation will put the strain more than usual. It should not be so hard.
08.05.2020 15:36 # 13
aslanparcasi
raw gasoline is filled in your catalytic converter.
