Tape speaker problem
08.05.2020 18:40 # 1
LeckenJugend
Friends I'm considering installing a system for my 2010 model 206+ vehicle as follows. But would it be a situation that the tape outputs would burn because I would use them without amps? or a situation like not getting a yield? So in short, does this tape work with these speakers?
Tape: Pioneer DEH-1650UB
Front Speaker: JBL Cs-6c 16,5cm Component
Rear Speaker: Pioneer TS-G132CI 13cm
08.05.2020 18:40 # 2
madblueblacksea
As long as you do not consider the output impedance of the tape less than 4ohm, it will not be a problem, but since the JBLs have high rms value, you can not fully feed and get high volume. If you say quality is important, not loudness, it is an ideal choice. Listening at high volumes for a long time tired the tape but this is a fact
08.05.2020 18:40 # 3
LeckenJugend
So which speaker should I buy without changing the tape? So what should the watt or rms value be?
08.05.2020 18:40 # 4
Alicilik
15w rms either available or not. As far as possible, try to take coaxional speakers to the component. If you can find Alpine and Kenwood, the paper series gives very sweet tone.
I used a one-way 16cm pioneer for a while and a 3-way oval on the back gave a nice sound with the original tape, but pert after 75% of the volume setting. Be prepared for this, when your last voice is gumbur, it doesn't bounce, on the contrary, everything gets muffled.
08.05.2020 18:40 # 5
LeckenJugend
So if I buy a powerful coaxional speaker, can I get clean sound when I turn on the last sound?
For example; Alpine SXE-1725S to the front. RMS power 60W
. Alpine SXE-1325S backs. RMS power 35W
Would it be a problem if I plug these speakers in the last voice? leckenjugend 2014-07-06 10:37:43
08.05.2020 18:40 # 6
Alicilik
I do not know the level range of the sound, but even in most amplified systems, if the output rms and the rms of the speaker do not match, the sound will deteriorate after 75-80%, it is very difficult to prevent this, especially in ampeless systems.
The products you mentioned are not bad compared to the past but it is worth replacing the output with a more powerful tape like the pioneer sony, even if the original tape is not the amp. Believe me, the sound makes a big difference.
After the speaker change I mentioned before, I tried sometime pioneer tape. Even if the sound settings were normal, it sounded better than the original. Even more costu after echo and level adjustment
08.05.2020 18:40 # 7
LeckenJugend
I will already replace the original tape with the pioneer DEH-1650UB tape. these speakers will work with pioneer tape. Do you think I should buy component or coaxional for pioneer DEH-1650UB tape?
08.05.2020 18:40 # 8
Alicilik
If there is no amp, do not enter compenant much. You can burn the sound outputs. If only tape outputs are to be used, the preference should be for coax. If you can find paper cones satisfy you.
08.05.2020 18:40 # 9
LeckenJugend
do you mean the speaker with a paper cone is the flat speaker used in televisions or something? One way without tweeters.
I mean, I will occasionally make a last sound and travel. I'll tie a woofer in the trunk. what are the speakers I should buy? for front and back. If I am not mistaken, the front is 17cm, the back is 13cm. If you give a link from a site like hepsiburada or gittigidiyor, I will pass the order right now. leckenjugend 2014-07-06 18:12:04
08.05.2020 18:40 # 10
Alicilik
If you are going to enter Haci bass, then the amp will enter the work, so if you look at the compenant,
Tweeter i have separate coax speakers. Most of them are in the vehicle. There is a paper cone speaker in the Auris, and when the voice is heard, the folks ask where did you hide the head.
08.05.2020 18:40 # 11
LeckenJugend
I will take the amp but you said it would be difficult to pass the cable from the amp to the doors. as far as I understand a messy and risky business. I thought I would put the amp-woofer in the trunk by feeding the speakers on the doors from the tape.
