TAPE RESET PROBLEM AT CONTACT CLOSE
08.05.2020 17:55 # 1
206FR
I have the original socket system in my car, sony xplod mp3 player is plugged in, but every time I turn the ignition off, I reset it from the lighter, I said I will not get it from the lighter, I will not get it from the battery, I did not eat it, because I did not know the cables.
08.05.2020 17:55 # 2
samet2461
What to do in the user manual of the tape recorder. I solved my problem by changing the red and yellow wires to. writes in the manual
08.05.2020 17:55 # 3
error
There is 3 ends in the feed of the teacher, usually one is chassis and the other is active, it is directly connected to energy. The third one is connected to the contact. Somewhere with .. & nbsp;
08.05.2020 17:55 # 4
206FR
Then there were two wires that were already + lead, one is yellow, blue is blue, electricity is supposed to come, so I'll try it at the same time. I don't have an electrician repairman, I do it all by myself. There were original sockets. I just hooked up the tape.
08.05.2020 17:55 # 5
error
you mean the signal sounds perpendicular to it "LOL"
joking aside If you do it yourself, take care of the insulation, use macarons instead of insulating tape because the insulating tape is opened in the heat, even pull the insulated tape over the macadam to be stronger ..
08.05.2020 17:55 # 6
206FR
Let me know if there are any of these crisp macarons.
08.05.2020 17:55 # 7
samet206
There was a yellow cable, it was connecting to its memory, it does not memorize, it resets every time it switches on and off.
08.05.2020 17:55 # 8
Alicilik
As the friends mentioned, the battery and contact cables are connected incorrectly and the problem is solved if you replace them.
Did you cut the cable?
