Tape Recommendation Hk. |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 21:28 | # 1 |
There is currently a pioneer (I don't remember the model) tape in the vehicle. When the owner before me said I was going to wear an audio system or something, he damaged the exit of the left sides. The sound is constantly sizzling. When I said let me change the tape, I wanted at least something useful and I would like to consult your ideas. With a maximum budget of 200 TL; with usb input, bluetooth connected, I am looking for a tape with a w / r input. Thanks in advance for the brand-models you can recommend. NOTE: additional sound installation etc. none, the vehicle's standard speakers are connected. I don't think of connecting an extra amp. |
| 08.05.2020 21:28 | # 2 |
EmSul |
If you are talking about the outputs of the tape, you will remove it when you have a Pioneer tape and take it for 200 seconds. If you are talking about the output of the tape, you are wrong.
| 08.05.2020 21:28 | # 3 |
Hello there. frankly, I don't want to change the tape. Why should I wear something, as you say, both financially and in terms of quality. When I say the sound output is broken, the problem I have is as follows; purple - back right gray - front right green - rear left white-front left tape outputs according to their colors. in my experiments with an empty speaker in my car and in my hand; The speaker that I connected to the purple and gray outputs gives a very clean, scratchy sound. however, when it is connected to the green and white colored outlets, there are popping sounds like both sizzling and small popping sounds. I thought that the cables may be getting chassis from anywhere in the vehicle, I tried the tape from the complete vehicle and we tried it at home with a 12volt adapter. |
