Tape recommendation for 206
08.05.2020 18:08 # 1
samet206
For 206, the front and rear doors are 16 cm to the front doors and 13 cm to the rear doors. - AUX should be without a CD Driver. There is not much CD anymore :)
08.05.2020 18:08 # 2
barishrocker
If you are planning to install a system in the future, the output of the amp is important. Let's say you got the mid team with the front and back doors and put sub in the trunk. For this process, you need to set the amp with 5 channels in total. For example, in the form of 4 channels and mono ... it will be the healthiest to draw 3 pairs of RCA from the tape to these amps. that is, I recommend you to choose a main unit with at least 2 outputs because you said that I will install the installation. I list my suggestions from good to bad:
http://www.atakantuning.com/pioneer-avh-x-8550-bt-bluetoothlu-kafa-cikar-double-teyp,pr-726.html
http://www.atakantuning.com/pioneer-deh-9450-ub-usb-li-oto-mp3-teyp,pr-532.html
http://urun.gittigidiyor.com/otomobil-motor-aksesuar/pioneer-deh-x7550-usb-sd-cd-mp3-oto-teyp-oto-cd-74955161
http://www.pioneer.com.au/au/products/deh-x6550bt/print.html
08.05.2020 18:08 # 3
korkusuz202
If you want price performance from pioneer's 1400 or 1500 series, you will be satisfied if you will install a pro installation in the future. You can follow your advice
08.05.2020 18:08 # 4
samet206
I do not want to install a professional system. As I said, I want to install speakers on the front and back doors of 206, I have to tape them up by itself. Thank you, but I do not intend to do something very well. Does Pioneer's MVH 1400 model work on what I am talking about? I can think of 159 TL in the homeland, but there was no control, and those who had problems with their demo, could not turn off, the device has cooled the device, and I want something more simple to use.
08.05.2020 18:08 # 5
barishrocker
If you say I do not intend to connect the door speakers to the amplifier, the models with a single amp output will also be suitable. you can get the product below. is a place where you do not assemble it, but it will not cause problems in product sales.
http://www.atakantuning.com/pioneer-deh-x-1650-ub-cd-mp3-calarli-usb-girisli-oto-teyp,pr-842.html
08.05.2020 18:08 # 6
EmSul
If you are going to buy the cd, I think it is sony and it is not cheaper than pioneer.
08.05.2020 18:08 # 7
barishrocker
[QUOTE = EmSul] If you are going to buy the cd, I think it is sony and pioneer cheaper sound quality is not different 139 lira
Sony plays softer and pioneer is brighter. Pioneer makes the sub and stomach stronger. I had the chance to try both.
08.05.2020 18:08 # 8
korkusuz202
[QUOTE = samet206] I do not want to install a professional system. As I said, I need to install speakers on the front and back doors of 206, I have to tape them up. Thanks for your peace, but I have no intention of doing something too good. Does Pioneer's MVH 1400 model work on what I am talking about? I can think of 159 TL in the homeland, but there was no control, and those who had problems with their demo or something that couldn't turn it off have cooled the device, and I want to read things like this, obviously I want something more simple to use.
I use mvh 1400, if it is installed correctly, it has no problem. You can open or close the demo menu. You can adjust the menu from 150 menu.
08.05.2020 18:08 # 9
samet206
I can think of Sony in fact, if you have a model that you like, I would appreciate it if you discard it.
08.05.2020 18:08 # 10
samet206
mhv 150 ub looks nice i can get this bimekste 160 TL Thanks for the advice ...
08.05.2020 18:08 # 11
korkusuz202
[QUOTE = samet206] [QUOTE = EmSul] If you are going to buy the cd, I think sony is no difference in sound quality cheaper than pioneer 139lira
sony i haven't tried but this new model output power 4x55 watts pioneer 4x50..media mark 139 tl campaign product (myrtle) meanwhile bimeks products are a bit expensive compared to normal market price
korkusuz202 2013-12-19 14:51:06
08.05.2020 18:08 # 12
barishrocker
If you look at it as 4x50w, it is misleading. They are their maximum strength. We have to look at their nominal or rms powers. Output voltage is also important. I used Pioneer and sony brands in the same system. Sony was sounding clean, but there was a clear difference when the pioneer was attached. I recommend alpine for clean sound and pioneer for strong sound.
08.05.2020 18:08 # 13
koramiral
44 TL I am using it, I am very pleased I bought 2 of them, someone went in the car I sold, I am using 206 now
vice admiral 2013-12-19 21:21:30
08.05.2020 18:08 # 14
samet206
Thanks for your advice, but I had a tape like this inexpensive way, navigold some keys were stuck, the buttons broke down, I tried to switch it on, but the output power of the tape is low 4x15 2 RCA output but it does not meet my requests. ringing so I decided to buy a solid head unit so it's more qualified.
samet206 2013-12-19 22:46:21
