Tape Installation
08.05.2020 21:21 # 1
selcukcolak6161
Hello friends. Can anybody remove the original tape of the 2004 partner and wear different tapes and give information about the installation?
08.05.2020 21:21 # 2
omerb
I attached the 206's tape. I don't know if the wiring is the same. I will help if you remove the tape and add pictures. Very simple.
08.05.2020 21:21 # 3
selcukcolak6161
Friends I put on tape. The original sockets of the partner directly fit the tape I bought. But sometimes the tape shuts off by itself, I think there is an electrical problem in the vehicle, somewhere there is a short circuit.
08.05.2020 21:21 # 4
omerb
Does the vehicle turn off while driving? Have you had your old tape?
08.05.2020 21:21 # 5
selcukcolak6161
It does not turn off while cruising. The old tape had a problem opening on its own, and since the original tape had no entries like usn aux, I had to install another tape. Something short circuits in the vehicle, but I can not find it.
08.05.2020 21:21 # 6
omerb
it's hard to find it. I think you'll have to go to the electrician. But you can look at the last thing you did in the vehicle. But go to an experienced electrician for this key issue, too, I think
08.05.2020 21:21 # 7
selcukcolak6161
Could there be a battery problem? These problems occurred in the vehicle after the battery was replaced. Could the battery amps not be enough?
08.05.2020 21:21 # 8
omerb
I hope you may have a problem with the battery then, there was no short circuit when installing the battery. & nbsp;
Did you see anything like that? Or there is a problem at the chassis (-) end of the vehicle. Check the battery cable. One of the cables may be & nbsp; internally disconnected. & nbsp; There may be chassis no-touch & nbsp;
08.05.2020 21:21 # 9
selcukcolak6161
Unfortunately, I wasn't there when the battery was installed. When the vehicle is in motion, there is no problem, but when the ignition is off, the tape turns off and reset suddenly after 5 minutes and the settings I made on the tape are deleted. Somehow they can't find this problem.
08.05.2020 21:21 # 10
omerb
Now the tape is shutting down and not turning on again.?
If so, could the vehicle be switching to economy mode ?? If you do not, when the power is cut, all station and tape settings will be reset.
08.05.2020 21:21 # 11
selcukcolak6161
When the tape is closed, it does not open, but when the contact is turned halfway, the tape is opened and reset. The tape was given 12 volts because the vehicles he made while in normal driving stopped exactly when I turned on the tape a certain time after stopping the vehicle. However, it stops working for a maximum of 5 minutes in a stopped state, suddenly cuts the electricity and turns off the tape. Mine is a very complicated problem Can BSI also be a problem 😢 & nbsp;
08.05.2020 21:21 # 12
omerb
peugeot has economy mode. After the contact is closed, the tape is closed after 1-2 minutes. Grab a minute. It always shuts down at the same time. If this is the case, it's okay. & Nbsp;
The tape has 3 cables, yellow, red and black. It is a yellow memory cable. & Nbsp;
It should be given +12 volts continuously. Check it out. Your problem looks like this. Of course, I don't know how accurate it is to say something without seeing it. & Nbsp; But the rankings don't fit. Look at the yellow wire you said. & Nbsp;
08.05.2020 21:21 # 13
selcukcolak6161
[QUOTE = omerb] peugeot has economy mode. After the contact is closed, the tape is closed after 1-2 minutes. Grab a minute. It always shuts down at the same time. If this is the case, there is no problem.
You said the tape sockets sat on each other. But the rankings don't fit. Look at the yellow wire that you said.
Then I think we will have to cut the original sockets. Is there a transformer apparatus for this
08.05.2020 21:21 # 14
omerb
yes there is a converter. You depend on the color. No cutting off the original socket, etc.
08.05.2020 21:21 # 15
selcukcolak6161
[QUOTE = omerb] yes there is a converter. You depend on the color. No cutting off the original socket, etc. [/ QUOTE]
So where can I find
08.05.2020 21:21 # 16
omerb
There are tuningers selling tape. I think 20-30 TL.
Can you add a picture of your tape to the forum
08.05.2020 21:21 # 17
Adem27
Mrb friends
ORIGINAL peugeot rd3 has been connected to USB aux and cloudut trials and the results are working now.
08.05.2020 21:21 # 18
Karacocuk24
[QUOTE = selcukcolak6161] [QUOTE = omerb] peugeot has economy mode. After the contact is closed, the tape is closed after 1-2 minutes. Grab a minute. It always shuts down at the same time. If this is the case, there is no problem.
Why do you need to cut the socket, the socket will stop, you just strip the middle of the cables coming to the socket and connect the new tape cable and the original socket will remain
08.05.2020 21:21 # 19
selcukcolak6161
No apparatus converting the original socket
08.05.2020 21:21 # 20
omerb
It is called the iso tape socket.
You plug that socket into the car's tape socket. Then, you tie the cables at the end of the tape to the cable coming out of the tape and tape it.
