tape does not work
08.05.2020 14:09 # 1
friends this evening I put antifreeze in the car I got into the car in the oil did not work the car did not work, reinforced from another car worked car alarm was broken self-activated electrician came dismantled the insurance of the alarm now the tape was canceled, my vehicle knows who wanted 2000 206 xr code respects their code
08.05.2020 14:09 # 2
MirakGTI
It is normal. If the battery terminal is out, the tape will prompt for a code.
If you write your car's chassis number to this e-mail address, n.guven@aktifiriyiloto.com will send you the code of the tape immediately.
08.05.2020 14:09 # 3
shamed
Miracles are halal Alkış
08.05.2020 14:09 # 4
friends I found the code tape in but it says error 3
08.05.2020 14:09 # 5
Aytac
[QUOTE = shamed] mirak is halal Alkış [/ QUOTE] powered by mirak.mirak has a secret garage samet bro, we burn oil stove, come over there warmth parts Sırıtma
08.05.2020 14:09 # 6
qaan
Hello ,
no life on tape?
the electrician shouldn't have taken the wrong fuse called alarm insurance?
If the tape is working and beeping, it will allow you to enter the code after half an hour and 1 hour.
if not, disconnect the battery then plug it in again
turn on the tape, wait again
But if there is no life on tape, take a look at the insurance
I hope you solve it.
08.05.2020 14:09 # 7
shamed
bro, i think you locked the tape, you tried the code, the solution is to remove the tape, remove the electrical socket behind it, re-insert it, the screen will be able to enter the code.
08.05.2020 14:09 # 8
shamed
[QUOTE = Aytaç] [QUOTE = shamed] Mirak is halal Alkış [/ QUOTE] powered by mirak.mirak has a secret garage samet bro Sırıtma [/ QUOTE]
my brother bigun come and get me warm up together: D
08.05.2020 14:09 # 9
aytacakoz
Greetings, the mechanic has disconnected the pole to change the battery. He wants bipper code right now. Can you help me?
08.05.2020 14:09 # 10
[QUOTE = aycakoz] greetings, the mechanic has removed the pole head to replace the battery, now he wants a bipper code can you help me? [/ QUOTE]
If you want to look at the answers in the title:
http://forum.peugeotturkey.com/forum_posts.asp?tıd=12371&pıd=174068&title=askerlik-bitti#174068
08.05.2020 14:09 # 11
Eyup Duygun
I am not sure of the 2000 model 206, but many peugeot tape-cdcaları do not work with the cod except for the old ones. The vehicle should be coded according to the chassis number.
