Tape, column etc. for 206+. want to get your advice
08.05.2020 16:07 # 1
Emperor905
Hello;
For my 206+ vehicle, I want to buy 2 columns for the back doors (I think it was 13cm) in the first place, and then I will take it to the front (I think it is 16 cm). can I get clarity and efficiency from these columns with the clarion brand cd player on the vehicle right now? I do not understand what kind of single-way double-way or channel or something. I do not think what is the only way or double-way. I am waiting for your suggestions and referrals. If there is a selling stuff, I can also consider buying it here. (Friendly prices are of course :))
thanks in advance ..
08.05.2020 16:07 # 2
Hodja, you want a small but functional thing like me: D
First, let me explain the following:
Front 165cm
back 130cm
If there is no line in the back, the room is a different problem. In some vehicles, the line never comes, in others, it stays on the bridge on the door pillar. It does not go to the door.
I bought deh2300UB. Nobody suggested it, but it is enough for me because I am not going to use the amp. The stalk dialer will soon be active on the next joystick. Teypd I am quite happy that I got the original turkey guaranteed.
I replaced the speaker of the front with the pioneer 165cm. Never touching the back. I made a mdf pandizot and put the oval speaker tilted ~ 20 degrees dike and tilted 45 degrees to the plane. There was no loss of image or a loss in luggage volume. They had a line inside the door sill in it, and I had a jack, so it was beyond wonderful to remove the sponge. When I turn on the bass, my heart is shaking according to the song. It is necessary to insulate the doors from outside.
I told you because we have the same vehicle. You can install the tape on your own. There is an ISO connection, but you need a converter for the antenna. The room has electronics. The front speaker replacement is also simple, but if there is no rear speaker, there will be a back trouble. & Nbsp; Reviews
08.05.2020 16:07 # 3
Emperor905
There are no hoppers in the back, and I think there is no installation either, the rear that makes me think is already. I do not want to have the vehicle outside for a further 2.5 years warranty. I'll give you 30-40 more if necessary, but I want to have a service job. 2011-09-14 00:04:36
08.05.2020 16:07 # 4
If you can, open the bridge between the door and post and compare the number of pins on both sides. & nbsp on the mast; The number of pins will be more than 2 (I have 2 pins unrequited so). If so, the door must be removed and a line must be drawn there. It's the simplest way. If this is the case, it is better to have a pendulum and use an oval.
08.05.2020 16:07 # 5
Emperor905
Thanks for your suggestions.
I am thinking of calling the service tomorrow and getting detailed information and prices.
08.05.2020 16:07 # 6
[QUOTE = Emperor905] Thanks for your suggestions.
I am thinking of calling the service tomorrow and getting detailed information and prices about it.
"Grin" If possible, write your interview with the service here tomorrow. I have been dealing with this issue since I bought the car and 10 people said hundreds of different things. I was wondering what he thinks about there. What price are they going to give?
08.05.2020 16:07 # 7
Emperor905
I called the service today and got a price. I told them to pull the installation of the columns that I will bring to the back doors. They said to me about 50 TL. I'm thinking.
& nbsp;
As columns, I am thinking of having Jvs branded double path 13cm columns recommended by my plumber friend. It has a price of 80-90 lira. Total cost will be around 130 lira.
08.05.2020 16:07 # 8
I bought the ovals at that price: D
Service wanted a little too much. The speaker would even make it where you bought it, but of course the warranty is crippled.
I would say a total of 500 installments for pioneer deh2300UB tape 165cm front pioneer speaker rear mdf special pandizot and oval pioneer speaker total 500.
08.05.2020 16:07 # 9
In my car, the front and rear speakers have changed, but the tape is not enough because it is original and the sound is distorted when it reaches the level of 25-26. Unless you change the tape, do not touch the columns, and you will spend money in vain.
08.05.2020 16:07 # 10
Original tape outputs are very low Pioneers have 50 * 4 outputs. I use ovals without amps and sometimes I feel shaky: D
08.05.2020 16:07 # 11
Emperor905
Ali, my friend, I can not take the risk of breaking the warranty, which continues for another 2.5 years, so that I will not pay 15-20 TL, it would not be reasonable anyway.
I am not planning to change the tape right now. The performance of the columns and the tape in front of me is enough, meets my expectations. It is important for me to go to the people sitting in the back, so I have two jvs right now.
Allah Kerim now let me see if I can not renew the vehicle, a solid installation next year.
Thanks for your comments and suggestions ..
Emperor905 2011-09-14 22 : 34: 02
08.05.2020 16:07 # 12
hakann83
My friend, don't break the original, get the door or something, cut a little back, tie two girths, then look how it tastes & nbsp;
08.05.2020 16:07 # 13
bornova
When I want to change the speakers of my 2004 partner car, the front door is 16 cm or 17 cm speaker, and the back is probably 10 cm. thanks...
08.05.2020 16:07 # 14
bornova
no one to help ??? "Banned"
08.05.2020 16:07 # 15
34sea45
front 16cm back 13cm should look jvc speakers
08.05.2020 16:07 # 16
No matter what you wear, I would say no wonder from pioneer, years of experience and quality, but attention to china goods has too many copies made in china.
08.05.2020 16:07 # 17
[QUOTE = bornova] When I want to change the speakers of my 2004 partner car, the front door is 16 cm or 17 cm speaker, and the back is probably 10 cm. thanks ... [/ QUOTE]
I enter the servicebox with the chassis number and see more detailed from there. Partner owner heleki 2004 model can not see this place. Reviews
08.05.2020 16:07 # 18
bornova
[QUOTE = Buyer] [QUOTE = bornova] When I want to change the speakers of my 2004 partner car, the front door is 16 cm or 17 cm speaker and the back is probably 10 cm. thanks ... [/ QUOTE]
thank you very much for the site you provided .... & nbsp; front 16,5 rear 10 cm
08.05.2020 16:07 # 19
[QUOTE = bornova]
Thank you very much for the site you provided .... & nbsp; front 16,5 rear 10 cm
Back between front and back between the front "Grin"
08.05.2020 16:07 # 20
bornova
Would I put 16 speakers instead of 16.5 in front of them ???
Page : / 2
