Tape code
08.05.2020 21:21 # 1
omera
Hello friends
every time I start the vehicle from me
wants tape code
I'm looking for a solution that does this
08.05.2020 21:21 # 2
There is probably a problem with the tape. I pulled it up so much that it never asked.
08.05.2020 21:21 # 3
omerb
Hi, I will unplug the tape in me etc. It doesn't ask for any code. There may also be a problem with your tape.
But he says on an overseas website. Check the fuse box. He says there are two fuses that are not in line with all fuses. One is lighter and the other is radio.
If the fuses are all lined up in the same position, you should find these two fuses. You have to put their leg up. The tool here can be different. You check it out. Act according to him, please.
I looked at some 206 fuse box pictures. Indeed, 2 fuses look different from the others.
While the user or the mechanic did not replace these fuses, he was putting them in line with the others. The problem was with him. I don't know if you are too
I think take a look. Hope it is solved. Please do not forget to inform us if you solve the problem.
