tape change
08.05.2020 17:56 # 1
emr_41_175
Hello friends, I changed the front door columns of my car last week but I think the original tape recorder is not enough for the columns. I do not show a fuel with a CD player with a USB player. There is no parking sensor in the car. I do not use any other tape, I would not affect anything other than the remote control, I do not even use the remote control now, and I am waiting for your tape suggestions.
08.05.2020 17:56 # 2
qqyyxx
No problem, just radio channels cd rds etc. As soon as the writings appear, other door open etc. warnings continue to appear, but make the electrical connection available to someone who knows that it is not a problem.
08.05.2020 17:56 # 3
emr_41_175
thanks
08.05.2020 17:56 # 4
Alicilik
I would recommend Pioneer-JVC-Kenwood-Sony-Alpine. There are slight differences in appearance and features between the same tape models (I'm talking about sub-series). Get a tape you find fit.
Make the assembly of the tape properly, as your friend said. Cable comes from BSi for both the contact and the battery. BSi adjusts the contact for a while because it adjusts the current and the electricians connect it directly to the battery or take the line from the contact. Don't worry, there is already ready. After attaching the tape, open the driver's window, close the doors and open the hood. Wait for 3 minutes, remove the battery terminal, wait 1 min, then put it back, wait another 1 min, and turn on the parking lamp without opening the door.
Possible problem on the screen is solved.
08.05.2020 17:56 # 5
emr_41_175
So how do I know which of the cables coming to the columns is plus or minus? I couldn't find the connection diagram of the original tape. I guess I connected the columns upside down.
08.05.2020 17:56 # 6
emr_41_175
When I disassembled the tape you said bide bsi, I saw a black socket that was idle. Could it be?
08.05.2020 17:56 # 7
qqyyxx
The brain that organizes all the installations we call bsi. There is no + - incident in the columns, but you need to connect it in series to get a full sound, I do not know the outputs behind the tape, but the jags entering the speaker are numbered 1 and 2. You can make a smooth connection by assuming 1 as plus or minus.
