Takur tukur sound from the back?
08.05.2020 17:20 # 1
ahmetismet
Hello friends.
& nbsp;
on 206 of your friend comes back and there is a constant noise. He says he has just started before ..
& nbsp;
There is nothing we checked to see that the spare wheel is loose. Why does it cost a lot?
08.05.2020 17:20 # 2
ufuk91
At 206, there is always sound from behind. It feels like I bought it. Recently, a different voice has been added to it, maybe it is yours, the torsions in my vehicle are problematic and it is making sounds. But as I said, it is chronic in the 20s. Check the items in the trunk is the simplest, or if you can not locate the exact place when you say back, it may be coming from the doors.
malesf 206 has a different sound quality because the material quality is not very good.
08.05.2020 17:20 # 3
cnrars
He also rattled at the back of my vehicle and it seemed like imbalance and skidding, even though the role and balance were normal, torsions were not problematic, the sound I said came from behind came from the front, what did the table say, it had to change, but not immediately, he said it would be okay for a while. service.
You may have something in the back, something in the trunk, the seats, the doors, the spare tire or something on the trunk side, because I know that there is nothing to do in the back.
08.05.2020 17:20 # 4
werty
If you want my grasp, check the screws of the part of the trunk of the tailgate, it may become loose in time. It may cause the room to make a sound. >
my friends, there is a humming noise coming from under the car with 80 90's. why the problem may be caused .. ??
08.05.2020 17:20 # 5
cnrars
[QUOTE = werty]
If you want, you can check the screws of the part of the trunk of the tailgate, it may become loose in time. & nbsp;
friends, there is a humming noise when my car is driving from behind 80 to 90. why the problem may be caused .. ??
can make from balls, can be in transmission,
08.05.2020 17:20 # 6
serkan719
It comes from 80% Torsion.
08.05.2020 17:20 # 7
ahmetismet
Yes, friends, the right rear shock absorber is broken, 130tl to change, 170tl is also holding the rot heads. Authorized service price. I hardly believed the rot heads. Should I just replace the shock absorber?
08.05.2020 17:20 # 8
cnrars
If there are loker loker sounds, it can be a shock absorber, if it is already. Rot heads also cause problems with pejoes very often, if the tire size is bigger than normal, it causes problems more quickly, especially if the roads are noticeable, change the rot heads.
08.05.2020 17:20 # 9
osman_bora
rot cuya will tell you every sound if you are in istanbul, you have a rotcu in front of carfuor there is the same problem for me, we had the same problem.
08.05.2020 17:20 # 10
ufuk91
Wasn't the vehicle 206? What shock absorber are you talking about at the back: S
08.05.2020 17:20 # 11
_semihk_
[QUOTE = ufuk91] wasn't the tool 206? what are you talking about shock absorber you are at the back: S [/ QUOTE]
with torsion but there is also a shock absorber brother 206s ...
