Takuk tuk from behind in pits and rough roads |
| 08.05.2020 20:00 | # 1 |
| 08.05.2020 20:00 | # 2 |
Normal bro, these cars are asphalt cars, we all have this problem
| 08.05.2020 20:00 | # 3 |
My voice comes from the sound cover, from the back team or elsewhere, first of all, it is necessary to clarify and talk. |
| 08.05.2020 20:00 | # 4 |
Coming from behind, I guessed that if any wheel enters deep or bad road, I guess it is from the wedges, but where it hits, it sounds great big wedge is not wedge behind the wheels. I said I need it, I said, my torsion, my torsion sign, I do not remember the sword model in full swarm war 2003 since it is a chronic problem, why does not it sound definitely something is old.
| 08.05.2020 20:00 | # 5 |
Adem Kurtuldu |
There may be a shortage of torsion, the shock absorber may break out, the spare wheel may be hitting
| 08.05.2020 20:00 | # 6 |
Shock absorbers may break out. I had the same problem, I replaced the back with a monroe brand shock absorber and screwed the guards into the wedges.
| 08.05.2020 20:00 | # 7 |
barishrocker |
No torsion at 307. It shocks the wedges, the shock absorber is old now .. It also hit me, I used it with get first 2 years later, I changed the new shock absorbers ..
| 08.05.2020 20:00 | # 8 |
I recommend buying the original shock absorber and changing it to a couple.
| 08.05.2020 20:00 | # 9 |
The solution to the sibling problem is very simple, you can handle it with electrical tape at no cost.
| 08.05.2020 20:00 | # 10 |
obayazit68 |
How so
| 08.05.2020 20:00 | # 11 |
Peugeot 206- and 307 is a chronic problem, but the solution is so simple :) the service repairman I did not take left at last, luckily, I found it myself, the trouble strikes in every hole, and it sounds like it does not come from it at first. but what I said will be a meaningless smile on your face :) Just fix the part to the top, before doing this, tighten it in a few turns with the electric band.
