Takır Tukur Sound for 1 Week
08.05.2020 20:28 # 1
307XS307
Hello friends. Until 1 week ago, there was no problem, but in the last 1 week, where the construction was abundant and the roads were terribly bad, my work started to sound like a small pit because of my despise because of my work going and going through the pits fast. as if there was a jerry water in the car, it swayed and made a noise while passing through the pits. what is the solution to this?
vehicle 307 automatic 1.6 petrol lpg
08.05.2020 20:28 # 2
ben_erhan
Are the voices coming from the front?
If it comes from the front, it is necessary to look at it .. If it comes from behind, it is necessary to look at it if the damper bellows are idle.
08.05.2020 20:28 # 3
307XS307
A general voice teacher comes from behind in front. but only comes through the pits. I do not think there is a problem with the shock absorbers because it springs well where necessary. I have been driving the car for the last 1 week, especially on bad roads, and I think it might seem like a screw might have loosened.
08.05.2020 20:28 # 4
ben_erhan
There are many clips under the front bumper. The hood, the protection plate at the bottom, the lip, almost all of them are connected to each other .. polling with your hand, fix the shaking places .. especially they make a lot of noise on the bad road ..
08.05.2020 20:28 # 5
whisky
Probably the rods, hanger rods or the front layout need to change, if it makes the sounds in the smallest thing while going straight in the turns left and right. The front order of our vehicles does not like a little too delicate, so we have to ride the roads by giving them some value. the back may be from torsion, wedges or shock absorbers may have exploded. you have to take it all and look at it, but it is not written roughly, but the cost is not much. the front set is around 120 pounds, for example.
08.05.2020 20:28 # 6
Antiseptiq
The same thing happened to me, I was telling the master as if he was hitting the empty canister with a stick, I made it for 2 years, that sound was made last month, it was coming from the Z-rod, they also called the hanger rod, it is not a very expensive piece, but for the information.
