take it from here ...
08.05.2020 14:52 # 1
muhtesem
friends, as I said, they connected the vehicle to the pc, they gave me an order when the gas pedal sensor error appeared. I gave it 250 lira.
now they have installed the new pedal system and connected it to the pc, now it says butterfly position error, the price of it is 350 lira !!
god allah ya rahman ya patience .....
friend, what is it like to spend 307 money, now 250 pounds is trashed
When I get the butterfly cuff, it doesn't go away by one hundred percent.
Believe me, I couldn't sleep until the morning. What is this? It was a problematic car. I will say it. I don't know what to do .... I don't know what to do anymore. Ağlama
08.05.2020 14:52 # 2
did my authorized service do this?
08.05.2020 14:52 # 3
muhtesem
He made a special service and wants the mother of the authorized service ....
08.05.2020 14:52 # 4
then you will ask the service when you have it done
Didn't you say `` bro '', the problem is solved?
did you buy a second hand vehicle?
I am using zero 307 click demeıd mahs very satisfied 08 mdl
08.05.2020 14:52 # 5
muhtesem
2. I took the hand at 103 thousand km
08.05.2020 14:52 # 6
That means the owner of the car had eaten the bread of the car before winter. he did not look despised. You would show a master while you were taking it.
08.05.2020 14:52 # 7
hasimayaz
There is no shortage of sensors in Peugeot. You should not jump on every error on the computer. A butterfly cleaning is essential.
08.05.2020 14:52 # 8
Here we take the breath in the paintwork bodywork when buying a second hand car, but look, if there is a paint change, but nobody is looking at the mechanics, I bought a car with 6 parts, 307 how many years I did not say click, I put the mozot, I walked, the only cost was oil maintenance, while the car was changing to the engine before the changing paint. It is necessary to look very well, the fairing does not cost, but mechanical failure makes the car burn the man
Get well soon
disassemble the piece you appreciate throw it on the mechanic's head what is this brother playing with you or you are too soft be harsh talk about the consumer court ask for the bill, i will complain to the finances, scare or the cost will increase
08.05.2020 14:52 # 9
wldnsxc
the right diode from polatkap, while I was getting 206 gti, there were 3 accidents, the chassis and the engine that was important to me, I gave 125 ytl and I got it in the checklist, the engine chassis, the car was unharmed, there were blows in the body, I said it was in the paint and it was okay.
08.05.2020 14:52 # 10
the same problem is our 2007 model 207 grandfather, I run the car, but I rot the accelerator pedal, it is not running any gas at idle, it detects when it starts 3 or 5 times, and it eats gas, the air conditioner works off the air conditioner.
08.05.2020 14:52 # 11
ereneren
I think change your master, ask for a refund and if you do not get your money back, give it to the lawyers of the company and tell them that they will file a lawsuit and then publish it and distribute it in the industrial neighborhood without paying attention.
08.05.2020 14:52 # 12
tigerland
I think change your master. Are you residing in ist?
08.05.2020 14:52 # 13
selcukcivelek
If you think of changing your saddle master, I can recommend my self-service, the guys who know their job can be repaired rather than changing what they do not understand. You can see the cleaning of the butterfly. You can reach my mail address if you want advice on the master.
I selcukcivelek@hotmail.co
08.05.2020 14:52 # 14
tigerland
Hi master, I just went to my master for headlight control, I know, there is an inspection :) I asked you about your incident .. I am a master who works at an old authorized service that I call a master. :) the name is not a master, he is a master, so he said whatever he did :) he came from the same fault the previous day, he said he made a lot ..
08.05.2020 14:52 # 15
t@lip
Sister get past, I think start from the point that Hashem Master says, firstly clean the butterfly.
08.05.2020 14:52 # 16
okan77
My friend don't mind getting a new one. The throttle and pedal must be trained ... while the ignition is on, the bottom gas is made and something is done by the butterfly. I dont know exactly. This is the case in every 307 without a gas wire ... Especially after the butterfly is cleaned, synchronization is done ...
08.05.2020 14:52 # 17
okan77
Sorry, I remembered the process called adaptation ...
08.05.2020 14:52 # 18
bayelektronik
The problem of our friend with magnificent nickname has been determined from the beginning. Since he bought the car without showing it, the bread of the vehicle has been defeated. Your throat butterfly will change. I gave more than 100 money to look at the car and it would burn if I didn't buy the car.
08.05.2020 14:52 # 19
I understand you will be bored when there is no operation, I hope you will like it.
