Take a hand and solve this problem
08.05.2020 16:58 # 1
sukur
AUTOMATIC GEARBOX PROBLEM (Almost Ended) ---- Pressure setting difference / Recommendation ---- gave an error. Master (Not My Own Master & nbsp;) & nbsp; looking at this error, what he tells me is; The oil and valves will change for a total of 550 TL ... If it is not resolved, we go to the transmission revision from the valves using the valves to 2750 TL: S
Sure I went to investigate & nbsp; 20 & nbsp; TL. I found the electrovans from Şahin Peugeot, which was advertised in our forum, for 120 TL.
The oil is also 20 TL, but there is that who says it will definitely be MOBILE LT 71141 Who says it will definitely be MOBILE DATRON. Both of those who say this accuse the other of not knowing. I was left in the middle.
Let me have your comments
08.05.2020 16:58 # 2
sukur
Friends urgent! Is my car's transmission AL4? Which oil should I use? MOBILE LT 71141
08.05.2020 16:58 # 3
The oil is correct, LT 71141.
I wish you had the code of the Keske error not the itself. I think the logic of the master to approach the solution is correct. If the solenoids have not been changed so far, they must already be replaced. Remember, ECU software must be updated after the solenoids are replaced. If the place to make the change is not an authorized service, they may not be able to do this. Reviews
08.05.2020 16:58 # 4
sukur
[QUOTE = koliva] The oil is true, LT 71141.
If you had the code, I wish the error was not the error itself. I think the logic of the master to approach the solution is correct. If the solenoids have not been changed so far, they must already be replaced. Remember, ECU software must be updated after the solenoids are replaced. If the place to make the change is not an authorized service, they may not be able to do this.
If I take my valve off my oil and go to the authorized service? Who knows how many money they will get. So let me ask you if I don't make the necessary changes and update the software you call ECU, drop me in traction, fuel surplus, knock, etc. Will it continue to make problems like?
08.05.2020 16:58 # 5
[QUOTE = sukur]
& nbsp; If I take my valve off my oil and go to the authorized service? Who knows how many money they will get. So let me ask you if I don't make the necessary changes and update the software you call ECU, drop me in traction, fuel surplus, knock, etc. Will it continue to issue such issues?
I'm not sure, but most likely authorized services will not work this way. You can still go to a specialist garage and get a price. Sometimes surprises, discounts can come out "Smile"
The operating frequencies of the old type, that is, the solenoids you use and the new type of solenoids are different. This frequency parameter is fixed in ECU software. If no updates are available, new types of solenoids will work but not fully. You can experience the problems you mentioned. Software terms. There is water in it, you are getting something new. You will pay that much.
08.05.2020 16:58 # 6
sukur
Either you are right, but in these services, we are really putting people in the right place. At the age of 13, we get in the car and the guys get 700-800 TL in a trip. Let me ask you one last question. If I wear them like this. then if I make an appointment and go to the official office just for the ECU, will they?
08.05.2020 16:58 # 7
[QUOTE] Let me ask you one last question. If I wear them like this. then, if I make an appointment and go to the authority only for the ECU, do they wonder? [/ QUOTE]
If you want, ask the authorized service. Or ask the service you are going to do now. Maybe they will somehow throw software. Reviews
08.05.2020 16:58 # 8
istanbullu_3886
sukur my friend if you are in istanbul, you can have the update update
08.05.2020 16:58 # 9
istanbullu_3886
Except for the service, there are very good brain makers in Istanbul.
08.05.2020 16:58 # 10
What kind of automatic gearbox does this peugeot have?
08.05.2020 16:58 # 11
istanbullu_3886
I think you can get information from our site sponsors ecu tuned for this
08.05.2020 16:58 # 12
sukur
Yes there is Data Peugeot will do everything in Maslak. The software was also updating. Const. My problem is to be solved, guys. Now I want to get inside and get into a car.
Also, when this engine temperature reaches 90s, there is a case of shouting and shifting as if it was idle. Getting up as if someone hit you from behind. Our user named Monur has been very helpful. I asked him in private, but let's see if this is going to be a solution to him or will he see a different problem.
08.05.2020 16:58 # 13
arachnid
services are doing software work only. my solenoids & nbsp; i changed & nbsp; my problem was not improved. the software also said that it should be discarded & nbsp; & nbsp; koliva & nbsp;. but when I go to the service we throw the software but they said & nbsp; the problem will not be fixed. 1500tl revision was complete in special automatic transmission. I would never know if the software fixed the problem. if the problem doesn't recur & nbsp; & Nbsp; & nbsp;
