TAK TUK! ZZZZT!
08.05.2020 15:05 # 1
sukur
I am new in the forum. I MAY HAVE HAD THE SUBJECT WRONG!
Friends I have a 2 month old Peugeot 106 XS. Due to the dishonestness of the seller, who did not say that the car was burning oil, I had to go to the competition the week I bought by eating a big pile. Even though the engine is reset, the problems in my vehicle are not over. The subject title may have made you laugh, but just as I wrote. While my steering wheel is not hydraulic and it turns right and left, it makes ZZZZZT sound inside and outside. I can also feel the difficulty and trembling. This is not a problem when walking, provided it is not too slow.
Also, once I press and pull the brake, I get a sound like TAK or TIK once. I get the same sound, less on the clutch.
And when I first bought it, it made a faint sound when turning it to and fro. They fixed it for 250 liras, but. This vibration and forcing job bothers me. What should I do.
08.05.2020 15:05 # 2
ali oncu
According to the forum rules, you must introduce yourself first and then knowing friends will help.
08.05.2020 15:05 # 3
sukur
My name is Fatih, I live in Istanbul. I'm dealing with Graphic-Design works. I have a navy PUG 106 XS. In the frame you may wonder, my information is master. Hoşbuldum
08.05.2020 15:05 # 4
xdesign
You made a mistake, colleague. If you had the car put on the computer, it would have removed everything. So I was amazed how you didn't understand a fat-burning car. You don't have much to do after this time. If you do all the maintenance, you will get rid of bigger expenses. Get well soon.
08.05.2020 15:05 # 5
sukur
When I took him to the master, the car said good. As for the master (!) The engine has already been renewed. Now the problem is this is the vibration problem with the sound on the steering wheel. What is the problem? And this is a 98 Model XS. Are these going into the computer, old car?
08.05.2020 15:05 # 6
ali oncu
First of all, the vehicle is good and welcome to us. I did not understand what they did for 250 liras, but I recommend you to go to the industry with someone who knows the car because the scam too. the sound from the steering wheel is either from the front wheels or from the steering gear. you should have a good look at both of them, find the problems and act like that. Also, if a good master looks at the pads or disks for the brake, the pressure pad will be solved for other problems.
08.05.2020 15:05 # 7
sukur
Thank you Mr. Ali. Here is my problem. Since it is my first car, there is nobody familiar in the industry naturally. I live in Başakşehir. Can you or a friend send me somewhere here as a reference?
08.05.2020 15:05 # 8
[QUOTE = lap] When I took him to the master, the car said good. As for the master (!) The engine has already been renewed. Now the problem is this is the vibration problem with the sound on the steering wheel. What is the problem? And this is a 98 Model XS. Are these going into the computer, old car? [/ QUOTE]
Does the vibration on this steering wheel increase with speed? If it is increasing, it comes from 100% wheel bearings.
The sound when you brake can come from brake pads that are not seated or completely finished.
08.05.2020 15:05 # 9
sukur
Yes, maybe. I feel that the brakes are holding late and the deceleration is weak. But the sound at the wheel is absent when the car is walking. Comes only when standing and turning between 0-20 Km speed
08.05.2020 15:05 # 10
[QUOTE = sukur]
How is the condition of the wheels, especially ten wheels? Have you checked the balloon?
08.05.2020 15:05 # 11
sukur
The wheels are old, but there is no balloon situation, teacher. I want to ride my car comfortably, I have been a victim for 2 months now, my friends, my friends.
08.05.2020 15:05 # 12
[QUOTE = sukur]
Then there is only one thing I can tell you. I don't think of anything else.
1. This event may be caused by the studs that are not fully tightened.
2. If the tires have low air or are disproportionate, they may also be from it.
08.05.2020 15:05 # 13
sukur
Thank you, Master.
08.05.2020 15:05 # 14
insomnia
FATIH FRIEND, I guess you had the mistake of not taking your car to a good master. I think the last time I was selling my car was the end of the plate, the car was in the field, the repairman in the field was aman at first, looked at the plate, start the engine, stop the car, the car does not change in 50000, just the master said, just put the plate 05 behind.
08.05.2020 15:05 # 15
my friend war from the same vehicle, the sound coming from the front may be caused by shock absorbers and rods if the car is flat, my car was also flat and raised.
If the noise is broken when the gas is applied to the brake, it looks at the ears of the engine.
Does he do it while downshifting?
If he is doing, throw the gear in the foot clutch, wait, turn it down, push the gas like that, if it doesn't make the sound.
bidet try this ....
08.05.2020 15:05 # 16
sukur
My vehicle is not flattened. So if this is about the ears, what is the expense and what happens if I don't? Another question is that when they turn the steering wheel to the left and right, they say the deterrence from the steering pump is 200 liras.
08.05.2020 15:05 # 17
ALX
I have 106XS, 97 models.
Do not put the steering wheel in your head and do not change the pump, if it sounds when turning left and right, it changes the steering oil, the sound decreases. Put it in good quality transmission or steering oil (in red). It was brown when I changed it, especially when I switched on the ignition without switching on in the morning, it made a lot of noise, now it has dropped to very reasonable levels. You can't drop it to zero, don't waste money.
The front team is a disgrace. In each pit, there are soft sounds. Even if you have your front team made, it makes a sound in a very short time. Don't worry. As street art said, the vehicle could be flattened, little lift. Mine is flattened too, but I don't want to remove it. The tires may also be stiffened. When I bought a winter tire, the voices were reduced.
Motor ears - I spent the last 2 ear changes + labor = 100TL. When I leave the clutch a little faster while shifting and taking off, it sounds like TAK. It stopped at first, 2 months passed, sound started to come again. Engine ears are replaced if broken, if not broken, just adjust. The plug sound when shifting gears can also come from the playing front. Have your setting checked. I feel like you can't cut that sound, I couldn't.
If you have other problems, I can help, I suffered a lot ... Still occasionally upset ...
08.05.2020 15:05 # 18
When the vehicle is flat, the shock absorbers do not do much work, I just bought the car, the undercarriage with zero error was made from the visa, but the lower tool was zero but did I go into the pit, the sounds were raised, the sounds were raised, the sounds are somewhat reduced. As for alx, when you come, you will hear a sound like take off your clutch from the clutch on departures. Don't worry about it. Don't worry about it. My brother is a mechanic. He is interested in the car.
I say try it too ..
When it comes to the tremor event, if the rims are offset, I would definitely get a tie rod balance.
08.05.2020 15:05 # 19
I read every word carefully from the beginning to the end so that I will find out why the steering wheel is shaking, but I could not. I have the same question. My car is swinging left or right at very low speeds or where it stops. I would appreciate if we have a friend who knows the reason, who fell off the roof before and helped.
08.05.2020 15:05 # 20
[QUOTE = badires] I have carefully read every word from beginning to end so that I will find out why the steering wheel is shaking, but I could not. I have the same question. My car is swinging left or right at very low speeds or where it stops. I would be glad if we have a friend who knows the reason and has fallen from the roof and if it helps. [/ QUOTE]
Don't be rude on the rims ???
If the curb, etc. is hit, it may be skewed. it may be because of her dancing on the low face ...
Page : / 2
