taillight on the slope ...
08.05.2020 16:05 # 1
Burorak
When I go on a steep road with my friends, after a while, the stop lamp and the exclamation mark lamp that lights up when the hand brake is pulled out flash. The heat is normal, so it doesn't look like heat. I told him what was done day by day, okay they said okay they did the same problem again. What could be the problem and will it damage my vehicle?
08.05.2020 16:05 # 2
looking at the brake pads may indicate that it is finished.
08.05.2020 16:05 # 3
[QUOTE = Burorak] When I go on a steep road with my friends vehicle, after a while the stop lamp and the exclamation mark lamp that lights up while the hand brake is pulled out are flashing. The heat is normal, so it doesn't look like heat. I told him what was done day by day, okay they said okay they did the same problem again. What could be the problem and will it damage my vehicle? [/ QUOTE]
So, is there a problem in braking the vehicle when this warning comes out?
08.05.2020 16:05 # 4
Burorak
I did not feel a problem in braking. The lining is normal, said the place where I looked the car
08.05.2020 16:05 # 5
okan77
When the brake hydraulic oil decreases, it also does when descending and descending ... It flashes temporarily ... It is corrected by adding and level control is made ... It is most likely dot4 type ...
08.05.2020 16:05 # 6
[QUOTE = here] I did not feel a problem braking. The lining is normal, said the car where I looked [/ QUOTE]
This warning is most likely due to the low level of brake fluid. If the brake fluid is full, problems are sought in the linings. In addition to these, there is a switch to find out whether the parking brake is pulled or not. This key is also rare but likely to be corrupt.
08.05.2020 16:05 # 7
okan77
Or the brake pads will be checked soon after they are replaced with new ones.
08.05.2020 16:05 # 8
Burorak
Thank you so much. I know they put brake fluid, but let's see again Burorak 2011-09-08 12:55:40
08.05.2020 16:05 # 9
Brake Fluid Is Missing Great Probability ...
08.05.2020 16:05 # 10
Burorak
I went to the service, they put hydraulic in the service, even exceeded the maximum line there, but they said it would be okay, I said well. I tried the car on a hill, there is no problem for now. Thank you all
