taillight
08.05.2020 16:23 # 1
Bugra
friends, the rear right tail light of my vehicle takes water and stays inside as a drop. I thought about changing it, but I gave up that the new lamp would be darker and I would have to change both. now I say remove it and silicon, but how to remove? I don't know how the red & nbsp; outer part of the lamp will come out. I would appreciate if anyone knows and shares. & nbsp;
08.05.2020 16:23 # 2
_semihk_
I also bought the left stop :) vehicle (2005 206hdi) the vehicle is in stock .. in this case, I can't put a led stop. I siliconed the crushed space in the trunk a little less than outside, but it was not cut completely. You can handle it bro!
08.05.2020 16:23 # 3
06OzGuR06
After removing the glass, after drying it with a hair dryer, you can close it with silicone if there is a place that takes water from outside. Maybe it may crack or break while removing the glass. : 20: 09
08.05.2020 16:23 # 4
Ucyuzalti
If covered with transparent foil after silicon & nbsp; For example, transparent red foil
08.05.2020 16:23 # 5
by_imp
My right fog fog is also getting water, the headlight is half full of water.
08.05.2020 16:23 # 6
xpyhre
Hi friend, if you take a look at the link below, I hope that our master told us how to remove and assemble the rear stops that have been told.
http://forum.peugeotturkey.com/forum_posts.asp?TID=6265&title=peugeot-206-ledli-stop-montaj & nbsp;
08.05.2020 16:23 # 7
Bugra
THANK YOU FOR EWET FRIENDS INFORMATION AND SUGGESTIONS. YOU HAVE TWO "Hug"
