Tailgate replacement and H7 6000 xenon assembly
08.05.2020 15:56 # 1
During the return from the taut, the rear trunk has broken and broken, 2 days ago, I came to the front, and the batten came and I bought it, I had it painted, I made the plate lights white, while I had time, I inserted my H7 6000 xenos and wanted to share it with the skin.
our ahmetsk 2011-08-03 22:06:47
08.05.2020 15:56 # 2
What do you mean, brother? Sırıtma But there are no lies, the zenons opened the car Sırıtma
Meanwhile, the pictures are not visible.
08.05.2020 15:56 # 3
I didn't understand 2 of them didn't hurt
08.05.2020 15:56 # 4
[QUOTE = ahmetsimiz] 2 of them didn't hurt I didn't understand
there is no picture, brother Sırıtma
08.05.2020 15:56 # 5
asil16
no picture buddy Sırıtma
08.05.2020 15:56 # 6
Ahmet no photos page lost. Sırıtma
08.05.2020 15:56 # 7
I am correcting my brother, the image is wrong with the image
08.05.2020 15:56 # 8
You finally got it, brother. Anyway, I wish you goodbye to use the zenons. Sırıtma
08.05.2020 15:56 # 9
Good health to your hand. It is okay if you put the white led bulbs into the parks.
08.05.2020 15:56 # 10
thanks brother thanks berkay brother will be a zenon in the afternoon. Gülme our ahmetsk 2011-08-03 22:10:29
08.05.2020 15:56 # 11
metin
ahmet good luck new hat.
When it comes to xenons, either get a headlight with lenses or remove those xenons because the xenon does not show up in front of the road, so the xenon will be lit up in the halogen headlight and illuminates the ground outside of the road. Sinirli
08.05.2020 15:56 # 12
How do we disassemble the plastic part of the tailgate, I have to disassemble it and I couldn't see any screws or how can I remove it ???
08.05.2020 15:56 # 13
Oh, and I say, trim the blacks on the edges of the back plate with thinner, the white looks beautiful.
The following figure:
Cindy 2011-08-03 22:58:31
08.05.2020 15:56 # 14
I will make them, brother over time
08.05.2020 15:56 # 15
[QUOTE = Bahadır32] How do we disassemble the plastic part of the tailgate, I have to remove it and I could not see any screws or how can I remove it ??? [/ QUOTE]
bahadır brother is present in the pictures above
08.05.2020 15:56 # 16
mimitt
your hand is good for your work but the xenon selection has been completely wrong, you have bought from the bulbs used in lens headlights, xenon bulbs used in reflector headlights are different, I also recommend you to put your car in the headlight setting, to some extent this eye reduction will decrease.
08.05.2020 15:56 # 17
[QUOTE = text] ahmet good luck new adventurer.
yaw text, I do not get a lens on my daughter, I will clean the satin headlights and darken the inside, then I will wear the lens, it broke down due to the satin xenos, the car lit all the lights, it was 00:23 Dil Çıkarma
08.05.2020 15:56 # 18
[QUOTE = mimitt] health to your hand, but the xenon selection is completely wrong, you bought the bulbs used in the headlights with lenses, the xenon bulbs used in the reflector headlights are different, I recommend you to put your car in the headlight setting.
Really believe me, I don't want to jeopardize anything, but I just tried my xenos H7 6000 was present in my hand, I used them, I did not have watered zones, I sat on the headlights in the next time, I will make lenses to be removed and the zones will be worn.
08.05.2020 15:56 # 19
mimitt
I recommend you to buy xenon with digital balst, I even use the digital slim ballasts of the space brand as a ballast in my car, the malfunction lamp does not light up, it also stands for your headlights thanks to its small size.
If you think the lens is artificial, check out the link, they have prepared a nice set, http://www.dhgate.com/50-shipping-cost-g3-digital-slim-ballast/r-ff8080812b27df15012b27ec343d3f94.html
I think this can give an idea about the dimensions of digital balst :)
mimitt 2011-08-04 00:52:09
08.05.2020 15:56 # 20
can be in fact, I recorded the evaluation, thank you
Page : / 3
