tahini color lubrication in engine water tank |
| 08.05.2020 19:19 | # 1 |
sonerkyl |
| 08.05.2020 19:19 | # 2 |
Efe-Pojo |
not necessarily confused, because there is no other reason. it may be missing from the seal.
| 08.05.2020 19:19 | # 3 |
sonerkyl |
Thank you, teacher, I'll take it to the industry tomorrow without opening a big problem. |
| 08.05.2020 19:19 | # 4 |
Ahmet_ach |
the gasket may be cracked, if a few drops of oil come to the radiator, such results will occur when mixed with antifreeze. |
| 08.05.2020 19:19 | # 5 |
there is oil leakage, another possibility is weak |
| 08.05.2020 19:19 | # 6 |
sonerkyl |
yesterday I left the master problem, the cylinder head gasket changed, and I replaced the timing and circulation pump with the lid opened. I did not want to give extra workmanship in the evening. I write different parts and labor fees, it becomes an idea for friends who come here with the same problem. thank you to the friends who gave the advice.
| 08.05.2020 19:19 | # 7 |
sonerkyl |
As of last night, the total cost of delivering my car is 780 TL including labor 1-cylinder head gasket 2-engine cover grinding 3-radiator and cooling system cleaning 4-motor oil and filter 5-thermostat 6-pipe on the thermostat to the radiator has changed (since swelling has changed) 7-timing 8-circulation 9-v belt 10-antifreeze
