Tachometer, Oil indicator Inoperated Mileage Counter |
| 08.05.2020 19:39 | # 1 |
Until I found all the answers from this forum to all my problems, I am grateful to you. Thanks again to friends who want to help .. My vehicle 206 1.6 XT Gasoline 90 BG 8 Valve
| 08.05.2020 19:39 | # 2 |
sonerkyl |
There are many issues in our form related to tachometer problems, usually the problem is caused by problems with the engines behind the instrument panel, but if there is a problem with the electronic card, it will need to change or it may be related to voltage imbalance. http://forum.peugeotturkey.com/forum_posts.asp?tıd=41393&kw=g%f6sterge+paneli&pıd=559245&title=206-gostergelerin-sifirlanmasi-problemi#559245 |
| 08.05.2020 19:39 | # 3 |
Thank you, but none of your friends' problems here are the same as me. my km is not reset. meanwhile, the speed indicator is falling. tachometer does not work at all.
| 08.05.2020 19:39 | # 4 |
sonerkyl |
In the indicator engines, then your problem should be removed and checked, even one member in the forum was selling the indicator engines link below the http://forum.peugeotturkey.com/forum_posts.asp?tıd=37865&title=206-gosterge-paneli-parca
| 08.05.2020 19:39 | # 5 |
Hello, I wonder when you changed your last battery
| 08.05.2020 19:39 | # 6 |
aku changed in the 12th month of 2014
| 08.05.2020 19:39 | # 7 |
Remove the instrument panel and insert it. The socket may be loose. This type of malfunction may occur as a result of missing or overcharging the charger. It is a little difficult to detect when traveling with the vehicle. because it may be an occasional rather than a continuous situation. Finally, if the dashboard is faulty, it may be due to it. You need to convince the seller that you can find the dashboard from the testers and try it out. |
| 08.05.2020 19:39 | # 8 |
[QUOTE = sonerkyl] indicator engines then your problem should be removed and checked, even one member in the forum was selling indicator engines link below the http://forum.peugeotturkey.com/forum_posts.asp?tıd=37865&title=206-gosterge-paneli-parca [/ QUOTE] uh, we missed a friend. I talked and sold it to him. but thanks he directed me somewhere in the gardener, let me see if I will talk to somewhere tomorrow.
